H22a EG wiring issues - Honda-Tech
Old 03-06-2017, 06:25 PM   #1
Default H22a EG wiring issues
So I purchased a 93 hatch that has a JDM H22a running off a p06 ecu. It had been running for a couple months no issue but recently I had an intermittent no start problem. I thought it was the main relay but that wasn't it. I noticed I wasn't getting any spark at the plugs so I tested the dizzy (TD-61u converted to external coil) and no spark. While I was doing my testing I noticed the wiring was a complete hack job. Plugs were left hanging, some wires left exposed, and a whole lot of **** poor solder connections. Here's my problem, I wanted get a new harness as a sort of preventative maintenance and fix any wiring issues if have in the future but I'm not sure what I need. I purchased an obd1 p13 ecu and an internal coil dizzy (td-60u) but I'm not sure if a h22a1 harness will just plug and play. I think the engine is odb2. It has a 97 stamped on the block above the headers and from my research that means it was manufactured in 97. It also has the map sensor mounted on the manifold sand not the firewall which also points to obd2. Should I get an obd2 harness and use an obd1 jumper since p13s are supposed to run h22as or just use the harness I already have and plug the p13 in. Can someone tell me if the engine is obd2 for sure? I can post pics of the stamps and serial qhen I get home. Any help is appreciated.
If more info is need lmk. This is my daily and I want to get it running again asap.
Prorezz is offline   Reply With Quote
(video) H22A swap barely idles when cold and bogs/bucks when throttled (video) NFrank89 Honda Prelude 10 12-16-2015 06:19 PM
Help with 97 accord lx with h22a7 swap Michael LaRue Honda Accord (1990 - 2002) 1 10-07-2015 05:29 AM
H22A OBD1 Swap Mystery spray004 Honda Prelude 15 07-01-2015 04:01 AM
GSR swap no spark, no fuel please help!!! Emmanuelsdd Hybrid / Engine Swaps 4 04-19-2012 07:57 AM
wiring delimma accord2civic2prelude Honda Civic / Del Sol (1992 - 2000) 9 11-28-2011 03:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
