GSR into EG coupe mounting problems
I'm posting this because me and a friend have been having some trouble getting his gsr motor in his eg coupe. With all the mounts placed on the engine, the motor will set at I guess you could say... a 20 degree angle sloping down to the left. We cannot figure out what it is. The car doesn't have the front transmission bracket so I didn't know if this would have anything to do with it. Any help would be greatly appreciated. Thanks!
Re: GSR into EG coupe mounting problems (Ryan C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C »</TD></TR><TR><TD CLASS="quote">you need the gsr side and rear mounts</TD></TR></TABLE>
The car actually does have the GSR rear and side mounts. We had experienced with a d series tranny mount but it was too dark so we gave up.
Oh well.
Oh well.
Re: GSR into EG coupe mounting problems (egcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">i thought taht u could use the eg mounts with a gsr swap. my friend did it and he said it fit like a glove</TD></TR></TABLE>
i used all the gsr mounts in my EG...
but i THINK you can use some of the EG mounts for the gsr...
Re: GSR into EG coupe mounting problems (sloboy_hatch)
You can use either GSR or EG side and rear mounts,though I believe you need the GSR rear bracket.Unless the mounts are broken,the frame is bent or the mounts are frmo a different engine it should fit perfectly.
Fuster_Cluck
03-25-2003 06:36 PM
