GSR IAB Wiring Question - Honda-Tech
Old 02-25-2017, 03:03 PM   #1
Default GSR IAB Wiring Question
I'm currently swapping in a JDM B18C GSR engine with a P72 ECU into my 1995 integra that originally came with a B18B. I have almost everything done but now that I'm finishing up the wiring I ran into a problem with the IAB wiring. I'm using two different diagrams that both say one of the IAB wires goes into the pin location of A20. The problem is I already have a pin in the A20 location for the EVAP purge Solenoid. I'm not sure if I should splice into the existing wire or remove it and relocate it, and if so where? I don't want to start the car and have something wired wrong so any help would be greatly appreciated.
For reference these are the diagrams I'm using
Captain Geech is offline   Reply With Quote
Old 02-25-2017, 07:07 PM   #2
94 Civic Si's Avatar
Default Re: GSR IAB Wiring Question
Both of those seem to reference A17 for IAB...
94 Civic Si is offline   Reply With Quote
Old 02-25-2017, 07:08 PM   #3
This thread might help you as well:
94 integra Ls to gsr swap IAB question.
Old 02-25-2017, 07:20 PM   #4
The light purple dot in the last picture is marked incorrectly... A20 is actually a controlled ground that operates the EVAP/Purge system. The second wire in the two pin connector at the EVAP/Purge valve is actually the 12v+ wire... which is essentially a switched 12V+ signal. The two pin connector at the IAB solenoid also uses a 12v+ switched wire... and the other wire is the controlled ground from the ECU at A17.
JRCivic1 is offline   Reply With Quote
Old 02-26-2017, 06:54 AM   #5
Thanks guys that clears it up. I already have one wire in the A17 pin so it looks like I just need to splice the other wire to a yellow/black 12v+ wire.
Old 02-26-2017, 10:47 AM   #6
You got it now !!!
Old 02-27-2017, 11:43 AM   #7
Quote:
Unless you are me, and you do that, and IAB still doesn't work!
Diagram needed Roy Leyva Engine Management and Tuning 2 03-17-2017 08:03 PM
J series Insight Build ChokeOnMySmoke Drag Racing 86 03-16-2017 05:49 PM
Golden Eagle Sleeved Block, CP Pistons, Manley Rods boosted1996 Classifieds: Forced Induction 1 03-10-2017 08:19 PM
NE 1991 Crx SI GSR swap rust free Randy Crom Vehicles for sale 1 03-01-2017 08:30 PM
94 Ls 5 speed hydro transmission and matching Ls motor Hybridguitarist Northwest (Sales) 0 02-11-2017 12:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
