GSR IAB Wiring Question
I'm currently swapping in a JDM B18C GSR engine with a P72 ECU into my 1995 integra that originally came with a B18B. I have almost everything done but now that I'm finishing up the wiring I ran into a problem with the IAB wiring. I'm using two different diagrams that both say one of the IAB wires goes into the pin location of A20. The problem is I already have a pin in the A20 location for the EVAP purge Solenoid. I'm not sure if I should splice into the existing wire or remove it and relocate it, and if so where? I don't want to start the car and have something wired wrong so any help would be greatly appreciated.
For reference these are the diagrams I'm using
Re: GSR IAB Wiring Question
The light purple dot in the last picture is marked incorrectly... A20 is actually a controlled ground that operates the EVAP/Purge system. The second wire in the two pin connector at the EVAP/Purge valve is actually the 12v+ wire... which is essentially a switched 12V+ signal. The two pin connector at the IAB solenoid also uses a 12v+ switched wire... and the other wire is the controlled ground from the ECU at A17.
Thanks guys that clears it up. I already have one wire in the A17 pin so it looks like I just need to splice the other wire to a yellow/black 12v+ wire.
eg6hatch
07-10-2003 05:31 AM
