Gathering EK wiring information ...
#501
Re: Gathering EK wiring information ...
I'm using the p2p ecu and the auto trans 1999 Dx. Skunk2 manifold uses 2 pin iacv, getting cel for iacv. Has anyone used auto trans on vtec upgrade?
#503
No, using a Skunk2 intake manifold with two wire iacv. Converted wiring done . Car has no fast idle at start up, seems to settle down as it warms up. Idle screw on Skunk2 throttle body has no effect on idle speed. Idle speed is 550-600 rpm.
Last edited by CRXSIR1; 11-27-2016 at 02:09 PM. Reason: corrections and additional info
#505
Is that because there is no connection from ecu to B23? Trans is computer controlled so I can't use a manual ecu right?
#506
thanks
#507
Looking for some help or advice
I have a 96 Ek hatch
b18c JDM from a 97 JDM GSR
P72 JDM ecu
just got a harness from 96 ex 5spd US
I noticed off the bat that the TPS connector is different on the ex harness, which I have not seen mentioned anywhere on this thread. Any mods that will need to be done besides swapped tps connectors?
also wondering if I'll run into any issues with ckp, code 91, or anything else using a p72 jdm ecu that came with my motor. I see everything is "if US ecu is used...." But nothing about a JDM ecu.
thanks in advance!
P72 JDM ecu
thanks in advance!
#508
I’ve read through this entire thread and didn’t see my exact question answered but if it has, I apologize. I’m using a D16Z6 from a 94 ex, wiring from my 96 CX, obd2a to obd1 adapter plug to p28 ecu, adapter to z6 dizzy, did 2 wire aicv plug conversion on wiring at intake. Do I need to also change the wiring at the plug moving A14 to A12 or does that only pertain to a mini me swap? Thank you in advance!
#509
Hi, Im putting a b18b1 from a 97 integra into my 00 civic hatch (dx). So I am plannign to use the wiring harness from my civic and the OBD2a p75 ecu from the integra. I purchased an adapter for the distributor. If I buy an adapter for the obd2b wiring harness to the obd2a p75 ecu from the integra should I be all good to go? Is there anything else that needs fixing? also how hard would it be to wire this myself as opposed to buying a jumper harness.
#510
So let me ask this. Do I need to do the bypass if my harness has the cpk sensor plug and my motor is obd1? My distributor is also obd1. So it should have the cpk within. Correct me if I’m wrong now. Also my car cranks but doesn’t spark. I’ll reply with all my diagnostics after response back.
#511
enot767
12
07-17-2009 02:27 PM
