forged pistons and rods for a f23a1
Old 10-25-2008, 03:11 PM
newtothescene's Avatar
Default forged pistons and rods for a f23a1
ive been lookin for roughly a month and i cant seem to find a damn thing for the f23a1. anyone know of any companies or sites i can get some? finna turbo it, and the pistons looked fine, but im just paranoid cuz it has 185584 on it.
Old 10-25-2008, 07:02 PM
Default Re: forged pistons and rods for a f23a1 (newtothescene)
oh, and i was also wondering if i can use an ACT performance clutch disc on a stock pressure plate?
Old 10-25-2008, 08:41 PM
JDM_DC4_Fanatic's Avatar
Yes, you can use the ACT clutch disc with oem pressure plate.
As for the forged pistons, you can run K20A pistons, as the bore is the same. However, I wouldent bother with forged, I would just get high content slilca aluminum and run colder plugs.
If you need ANY engine parts for an F series engine, http://www.bisimoto.com is your answer.
Old 10-25-2008, 09:11 PM
Default Re: forged pistons and rods for a f23a1 (JDM_DC4_Fanatic)
learn something new every day. so, if another engine has the same stroke, can i run the same rods too?
Old 10-26-2008, 03:59 AM
P_Adams's Avatar
http://www.horsepowerfreaks.co..._Rods
P
Old 10-26-2008, 07:47 AM
AFAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you can use the ACT clutch disc with oem pressure plate.
If you need ANY engine parts for an F series engine, http://www.bisimoto.com is your answer.</TD></TR></TABLE>
I wouldn't advise someone of the OP's knowledge to run K20 pistons. They're far from a perfect fit, and I seriously doubt he's looking for 11.5:1 cr if he's planning on boosting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newtothescene &raquo;</TD></TR><TR><TD CLASS="quote">learn something new every day. so, if another engine has the same stroke, can i run the same rods too?</TD></TR></TABLE>
Unfortunately no. The stroke is determined by the crank. It's just not that simple. F23 rods are the 'bastard child' of Honda. They aren't interchangeable with any other engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">http://www.horsepowerfreaks.co..._Rods
P</TD></TR></TABLE>
Also: http://www.raceeng.com/searcha...t.y=0
Old 10-26-2008, 09:23 AM
Default Re: forged pistons and rods for a f23a1 (AFAccord)
guess i still have much to learn. damn f23. but i love my engine. Thanks everyone.
Old 10-26-2008, 09:43 AM
got another question: when i order pistons, do i gotta order the rings separately or do the rings come with it? also, when i order rods, is there anything else i need to order? sorry bout all the questions, just excited and dont wanna mess something up.
Old 10-26-2008, 09:56 AM
P_Adams's Avatar
Some vendors supply them as a Piston "Kit"; Pistons, Piston Pins and Rings.
Other vendors omit the Rings. The reason would be the customer's preference of ring type, due to Cylinder Metalurgy and Surface Coating.
You've all manner of types available:Chrome Moly, Cast Iron, Moly filled cast iron and others.
P
Old 10-26-2008, 10:09 AM
hon2984's Avatar
AZ RACE ENGINEERING ! crower makes rods for it, and CP makes two options for pistons 8.5:1 is one and the other wont help you because compression will be too high at 11.5:1.
http://www.azracemachine.com/contact/Contact.htm get a catalog sent to you!
Old 10-27-2008, 08:46 AM
Professor15's Avatar
just go with custom units, for the price you'll be better off. Start contacting some of the more popular manufactures and see what they can do for you.
Old 10-27-2008, 11:39 AM
Turbowa's Avatar
Default Re: (Professor15)
For rod's Crower and Pauter both make rods. Pauter is a little more but can be had quicker the Crower. As for piston's CP and Aries both have shelf unit's.
Old 10-27-2008, 02:23 PM
Default Re: (Turbowa)
cool. thanks everybody.
98savage
04-08-2013 01:48 AM
IamPhil
07-07-2008 06:20 PM
mrx
02-12-2006 01:50 PM
crexer
10-04-2003 06:28 AM
Quick Reply: forged pistons and rods for a f23a1
