Finished EK h22 Swap
Got it running about a month ago been drivin real nice. was kind of a bitch to do though.
The B16 came out real easy.
first problem was the right side axle was frozen in the hub. Tried sledge hammer
even a hydrolic press. The thing would not move at all.
My solution was to switch to gsr front Knuckles and brakes
Here are some empty engine bay shots
So then I cut my hole for the shifter assembly and linkage.
Install a exady clutch and jun flywheel.
do all the wirring and drop in the motor.
So hook everthing up get it started take it around the block. It starts surging like crazy. Bring it in find out the brake boster fitting hit the porportioning vale and cracked
Pulled of the upper plenum and drilled and tapped new 90 degree angle fitting and moved valve.
Some finished pics.
Modified by Jago at 12:01 AM 4/3/2006
Some finished pics.
Re: Finished EK h22 Swap (Jago)
looks like a fun car.....how does it handle now...i mean more in cornering and everyday driving.....wondering if it is similar to the EG with the H22 swap.....tends to push in the corners cause of the excess weight of the engine.....so i guess im asking is the car still comfortable and fast or crazy and fast???
https://honda-tech.com/zerothread?id=684550
Re: (Nova_Dust)
is your intake tube going to smack against your shock tower when the motor moves ?
also damn thats a tight fit for the prop valve, never realized it was that tight with h22
Re: Finished EK h22 Swap (t0pdogg)
Originally Posted by pnltnc
Very nice!!! were did you get the clutch kit and flywheel?? and does it hook pretty good?
I like the set up but I need some better tires these ones suck. Need some slicks for the track.
Originally Posted by XxIndoRacerxX
very nice...good job wit that swap...how long did it take u???
Originally Posted by Quad-Damge
how much fast would u rate the h series motor over the b16
u now have torque, but u can't rev it as high
Originally Posted by Prod
is your intake tube going to smack against your shock tower when the motor moves ? also damn thats a tight fit for the prop valve, never realized it was that tight with h22
don't think the intake will be a problem.
Originally Posted by cappa
Do you think its better than your B16? I was woundering why many people dont do that swap as much as the B16 one.
Originally Posted by Phatch99
good ****... how you like it? how much was the total cost and time you put into swapping it?
Originally Posted by Redline96LX
What are you doin with the B16?? Just like wonderin of course....like, if your sellin it. Cause im interested.
Jun stage three Cams and cam gears
Jun springs and retainers
Arp head studs
head is from a 1999 SI
Skunk2 manifold
Aem Fuel Rail
top fuel FPR
Jun Flywheel
clutchmasters 4 puk clutch
DC 4 to 1 header
Hondata EMS with P28 with JUN stage Three program
Skunk2 short throw on shift linkage.
Looking to sell complet was thinkin 4k with everthing
including mounts and all. Short one axle though
also can get a good deal of the stock parts.
