failing VA emissions inspection..
Old 03-13-2002, 01:19 PM
MeanGreenEG9's Avatar
Default failing VA emissions inspection..
I failed for too much hydrocarbons at 25 mph but not at 15mph... My car was warmed up well before the test.. I even tried that emissions test passer fluid but i still failed! what can i do to fix this? this is my setup
d16y8 sohc vtec
akimoto intake
dc sport header
5zigen catback..
Old 03-13-2002, 01:32 PM
FLIP2daMaX's Avatar
Default Re: failing VA emissions inspection.. (EKb18b)
u check u'r timing?....my old car alwayz failed the emissins, because my old mechanic f'd up the timing gears.....but now it passes...
Old 03-13-2002, 01:48 PM
Default Re: failing VA emissions inspection.. (FLIP2daMaX)
I should advance timing if rich correct?
so far i think i will
adjust timing
get new spark plugs
make sure the car is warmed up like crazy
anything else?
Old 03-14-2002, 06:24 AM
Trey's Avatar
A/F controller like the Fields of VAFC will let you lean out the fuel at low rpms and that will help you pass....... That's what I did.
Old 03-14-2002, 07:41 AM
New User
Kalokohan's Avatar
Default Re: failing VA emissions inspection.. (Trey)
That would probably be your best bet.
tianporn
03-25-2005 09:02 PM
incubus
14
12-26-2003 06:20 PM
sleeper4dr
02-26-2003 04:44 PM
MeanGreenEG9
30
04-01-2002 01:15 PM
Quick Reply: failing VA emissions inspection..
