f23(h23) swap into 96 civic, injector/ resister ???? - Honda-Tech
Old 08-21-2004, 05:40 PM   #1
BOMBCRU's Avatar
Default f23(h23) swap into 96 civic, injector/ resister ????
did a engine swap into a 96 civic using the dx civic harness, the motor is a acura cl f23a1 same as a accord motor, do i have to wire in the resistor box so i can run the injectors? i got dsm 450cc injectors going in later on when i get my maniolf in for the turbo but until thendo i have to have the resistor to run the factory injectors or will my chipped p28 run them??????????????????
BOMBCRU is offline   Reply With Quote
Old 08-23-2004, 03:22 PM   #2
BOMBCRU's Avatar
Default Re: f23(h23) swap into 96 civic, injector/ resister ???? (BOMBCRU)
bump
F23a1 with d16 ecu Thomas Settle Honda Accord (1990 - 2002) 2 09-06-2015 08:48 PM
injector/resistor box problems and issues dnaDC2 Acura Integra 10 05-29-2012 03:19 PM
Am I supposed to have a resistor box on my b swap? Cap'N Chronic Honda Civic / Del Sol (1992 - 2000) 3 08-30-2011 03:39 PM
What defines the need for the injector resistor box? immorality Honda CRX / EF Civic (1988 - 1991) 4 05-24-2008 04:46 PM
removing resistor box?? Rob! Forced Induction 7 06-21-2006 06:27 PM
Tags
95, accord, acura, box, civic, cl, ek, engine, f23, factory, h23, injector, injectors, resistor, swap, turbo, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
