f20c swap in civic ej9
Old 02-24-2009, 12:19 PM
  #26
voodooo's Avatar
Default Re: f20c swap in civic ej9
f20c flywheel modificated
Adapter plate to k20 gearbox
not good
ok now to the alluminium
(80€) 131x51x1.5cm 28kg di peso
designed
Old 02-24-2009, 12:32 PM
  #27
randomnineh2b's Avatar
wow this is very innovative good job
Old 02-24-2009, 11:31 PM
  #28
voodooo's Avatar
the manifold intake gasket
cut
after 4 hours :D
is arrive the k20a2 gearbox with jdm lsd :love
Old 02-24-2009, 11:41 PM
  #29
voodooo's Avatar
ok now fitting the gearbox,
not good
is arrive the exaust manifold, is for k20 swap to eg-ek-dc
no fitting over the f20c fead but is very similar
now the measure(mm)
now the comparation to k20 and f20 exhaust head
final cut
more pictures
Old 02-24-2009, 11:50 PM
  #30
voodooo's Avatar
now this is a stock setup
this is a tuning setup :D
for created the space to the mounth
at work to the mouth
not good... is very breakable
the modification of the modification :D
ok is good came on
very pretty :D
perfect
Old 02-25-2009, 12:01 AM
  #31
voodooo's Avatar
ok go to the axle
the work in my house is finished, now go to the officine
:D
in the officine
in my car
a comparation with the ex engine(b18c6)
the measure in cm
the weight
b18c6 110kg abouth
b16a2 95kg abouth
f20c2 92kg abouth
prepare the car
after
later
the innovative engine mouth
for dadozh22 is ok :D
the mouth tuninig
in the car
Old 02-25-2009, 12:07 AM
  #32
voodooo's Avatar
the engine mouth
the radiator is for fiat panda :D
:D
next time the new picture!
Old 02-25-2009, 05:09 AM
  #33
DSRxCandyh2bEG's Avatar
Wow, good job!! good work designing/fabricating the mounts...
the ej9 comes with a b18c6??
what country are you in?
Old 02-25-2009, 06:22 AM
  #34
voodooo's Avatar
tnx no no my ej9 have the d14z3 (1.4 90cv) the first swap have b16a1 (1.6 150cv) the second is b18c6 (1.8 190cv)
Old 02-25-2009, 08:38 AM
  #35
Jaker's Avatar
Wow, that header is close to the ground. Be very careful. I hope you can manage to raise it up somehow. I've had my share of headers crushed on the bottom from being too low.
Old 02-25-2009, 08:43 AM
  #36
voodooo's Avatar
sorry but in that photo the exhaust manifold isn't mounted
Old 02-25-2009, 10:32 AM
  #37
sciamutanna's Avatar
Our country is the little Italy...
Old 02-26-2009, 05:43 AM
  #38
something different
redzcstandardhatch's Avatar
do you have to space the flywheel closer to the trans so the clutch can engage/disengage, or does the f20 flywheel/k20 clutch compensate for that?
AWESOME work...very cool
Old 02-26-2009, 07:05 AM
  #39
voodooo's Avatar
i have used the b18c6 relase bearing for this problem
Old 02-26-2009, 07:08 AM
  #40
voodooo's Avatar
the b18c6 relase bearing is more high than k20a2
Old 02-28-2009, 10:36 AM
  #41
voodooo's Avatar
Old 02-28-2009, 11:49 AM
  #42
C_Rock77's Avatar
Great stuff! I like the custom engine stand :-P
Old 02-28-2009, 12:05 PM
  #43
I serve phở for my babies
ohsnapzafingcu's Avatar
wow. wtf hahaha
Old 02-28-2009, 01:12 PM
  #44
voodooo's Avatar
tnx
Old 02-28-2009, 03:55 PM
  #45
jdmeurorlude's Avatar
great to finally see this swap done, i really want to buy an ek project car and do this.
Old 02-28-2009, 06:39 PM
  #46
.Hatches.'s Avatar
amazing stuff.
Old 02-28-2009, 11:54 PM
  #47
BlueIntegraBoy's Avatar
Great build. Very tight squeeze for the intake manifold.
Old 03-01-2009, 09:20 AM
  #48
S.P.I.cc's Avatar
Thats F*ckin awsome!!!!!!
  #49
S.P.I.cc's Avatar
good luck on the build
Old 03-03-2009, 11:58 PM
  #50
voodooo's Avatar
last video :D
http://www.youtube.com/watch?v=nxvjob222FY
and this is the view of cluster
http://www.youtube.com/watch?v=oEDXn2nnupo
Quick Reply: f20c swap in civic ej9
