F20b motor swap crank sensor help
Old 05-11-2015, 05:14 PM
Koofy23's Avatar
Default F20b motor swap crank sensor help
Dear everyone I've spent countless hours and dollars on this f20b swap in my 96 accord. I've done a lot of research and I'm stuck because the motor cranks and the fuel pump engages but I have a no spark issue. I would like to remain obd2 in order to pass emissions. My question is if I use and obd1 dizzy with an internal coil and crank sensor with a stepdown harness on an obd2 ecu will the ecu be able to get the crank sensor and other info from that dizzy or am I screwed and have to go obd1. Thank you in advance for any help. its all welcome
Boostdprotegelx
05-30-2016 10:29 AM
caleba1
08-31-2012 10:25 AM
nels00n
19
08-16-2010 08:04 AM
Spence
10
04-24-2006 09:37 PM
blowbyu24
10-24-2005 09:53 AM
Quick Reply: F20b motor swap crank sensor help
