EG AWSD (H22 turbo 4WD and 4WS)
#451
#452
Re: EG AWSD (H22 turbo 4WD and 4WS)
you can follow the engine rebuild here
https://honda-tech.com/forced-induct.../#post50941546
#453
Haha le Vin a gre de merde,
Bonjour from Bulgaria,
I guess this is one of the reasons never trust the mechanics... women and cars must be fixed by yourself...
I would express all in a bad French but let's keep it clearer for the folks all-around.
Like your garden engeneering, is very close to what we have over here, only we called beer banking crew engeneering,
We perform it locally when a bunch of rednecks try to avoid wife's Sunday cleaning attitudes, under lifted bunny rockets.
So on Xooimage
I was wondering what vehicle subframe you have used for the rear Beam. As my self pretty much need to fabricate one, I could use your idea instead of design, laser cut, bend and weld.
Check out my thread MB8 awd, you can find some ideas about rear hub bracket, and less mod using original Civic Trailing arms. You will have to weld, but much less, thus keep rigidity.
Also don't give up on the ABS, you can install the Rings in the inner cv joints instead. Only you will need Custom bracket to mount the sensors to differential side.
Me personally have the HRV rear differential as mechanically and ratios are the same, but have extra 4 studs on the front casing.
Send me a PM and will pass you the hub 3d
cheers
So on Xooimage
cheers
#454
Hi mate!
I have the ABS on mine. with CRV hub at the rear.
I removed the stock bolts and remplaced by 12.9 bolts and it's reliable.
I'm sending a pm, thanx
#455
#456
#458
#460
Thanx Mate
I must always find the time to reload the pics on the old pages.
in waiting for, we can see those olds pics on my website, here:
Civic AWSD - Soxle
better pics
some news
runners at the color of the car
and the soxle oil cap
a red stig girl who was in the garage
porting between the head and the runners of the intake manifold
rod bolts
port and polish turbo housing
timing tag
custom manifold of the oil return of the dry sump (arc welding)
reinforced camshaft bolts (not in aftermarket and good for the reliability (11000 RPM)
you can see also the nordlocks
EGT.
new clutch system (tilton)
look the oil pump on the block.
destroy a fullrace down-pipe and enjoy! ^^ (with a cut-out)
4" diameter
new sub frame (with pieces of the H22 subframe).
modified catch can !
the engine in the car
oil radiator after the scavenge pumps
turbo cooler + electric water pump
Civic AWSD - Soxle
better pics
some news
rod bolts
timing tag
EGT.
4" diameter
