driveability problems... - Honda-Tech
Old 03-01-2012, 05:09 PM   #1
Default driveability problems...
Ok so here's the thing, I bought a 92 hatch with h22 swap already done( yes I know that's my first mistake, but I got it very cheap). Here is my problem, it idles quite low about 400-500rpm, it also misses at low, some times throughout, the rpm range, and once I've been driving for a while, rpm's fluctuate at that low idle. I took a look at the ecu n its a p06, but I know its been chipped cuz it does hit vtec and I've revved it up to 8k(jus to c where the limit is at) n of I remember correctly, a stock p06 cuts out at 6800. I've been thinking about jus getting a chipped p28 from phearable.net jus so I know excatly what I have running my motor.
My question is, do u think I should get the p28 jus to b safe, or should I save the money, do a good tune up and figure out what is up with the p06 and get it re-tuned?
Any help is greatly appreciated!!
EGhatch-dueceX2 is offline   Reply With Quote
Old 03-01-2012, 05:16 PM   #2
The Grumpiest
grumblemarc's Avatar
Default Re: driveability problems...
Check the timing. Adjust the idle.
grumblemarc is offline   Reply With Quote
Old 03-01-2012, 05:23 PM   #3
Your thoughts on the ecu?
Old 03-01-2012, 05:40 PM   #4
The Grumpiest
Leave it. What people have to understand is that once an ECU is chipped it makes no difference what it started out as. It's like installing Windows on your PC then deciding you want to wipe it out and try Linux.
I have a chipped P28 and a chipped and converted P06. No difference in the way the ECU works. Only the MAP is important.
Old 03-01-2012, 05:42 PM   #5
The Grumpiest
Also do the tuneup. That was the FIRST thing you should have done when you bought the car.
Old 03-01-2012, 06:02 PM   #6
I agree but i don't have a clue as to what the MAP even looks like...
Old 03-01-2012, 06:08 PM   #7
The Grumpiest
The MAP is the program ON the chip that tells the engine how to run.
Old 03-01-2012, 06:11 PM   #8
So what your saying is these issues have nothing to do with the ecu? And to put the money towards a good tune up?
Old 03-01-2012, 06:15 PM   #9
The Grumpiest
Right now that's what I'm saying.
Old 03-01-2012, 07:06 PM   #10
K, Ty for the input
Old 03-02-2012, 05:02 PM   #11
Ok, so seeing as I have a CAI I don't need to replace the air filter since its fairly clean, and the fuel pump and filter are new, the only thing left tune-up wise is ignition components. I've read up on Nology external ignition systems and sound pretty good for the money( besides the fact the "hot wires" are almost a couple hundred alone which I will probably purchase at a later date and I already have 8.5mm wires now) This setup with some E3 plugs should do the trick. Anybody have any experience or insight on these types of systems?
Old 03-02-2012, 05:05 PM   #12
The Grumpiest
NGK plugs and Sumitomo wires. Can't beat the combo.
Old 03-02-2012, 05:11 PM   #13
Any thoughts on the nology setup? Worth the money for the external ignition, or no?
Old 03-02-2012, 05:15 PM   #14
The Grumpiest
I recommended the stock setup because it cannot be beat. If it cannot be beat then it goes to follow that the Nology setup in comparison is not up to the task. So that would be a "No".
Old 03-12-2012, 10:27 PM   #15
So, I did the tune-up (plugs, wires, cap, and rotor) and I'm still having the same issues. Possibly the injectors?
Again, it idles real low (300-400rmps) it misses in low rpm, occasionally throughout the rpm range. It RARELY happens when the engine is cold unless I'm in 4th or 5th goin 30-40mph and try to accelerate but never throughout when cold. If i don't put it under load and let it gradually accelerate, then it won't miss. It seems as though the longer I drive it, the worse it gets.....
Old 03-12-2012, 10:43 PM   #16
Did you adjust the idle and check the timing like he said? I might work fine when it's cold just because the idle is a little higher. So adjust that and see if that fixes it.
dlstech is offline   Reply With Quote
Old 03-13-2012, 07:11 AM   #17
No I haven't, it wouldn't have anything to do with the timing because it would do it constantly and not act differently whether hot or cold. Also I don't want to just adjust the idle because it would just be covering up the problem temporarily. Regardless I plan on replacing the timing belt in the next couple weeks.
I'm thinking the injectors, either they r going bad or whoever wires up the resistor box did something wrong....any opinions?
Old 03-13-2012, 07:22 AM   #18
Also for insurance, I cleaned the IACV, and throttle body still ending with the same result.
Old 03-14-2012, 08:56 PM   #19
noz79's Avatar
Compression and leak down test time.
at grumblemarc on schooling everyone on the p06 computer, everybody automatically thinks you need a p28.
If you have a stock h22 you can try another chip with a stock tune. I wouldnt use those ebay chips.
Get rid of the cold air intake, could potentially be the cause of the problem. Everybody thinks worse case scenario when you suck in water....hydrolock but sucking up water could cause a bent valve also. My friend recently had a chipped valve causing similar problems as you. Im not saying this is the problem but Im guiding you in the right direction. Do a compression test and a leak down test.
Youtube it if you dont know how to do it
noz79 is offline   Reply With Quote
Old 03-29-2012, 09:35 AM   #20
Ok so compression and leak down are good, I got 185 accross the board. I was finally able to get the car on a lift and found that there is no O2 sensor which I believe is the whole problem. I found what I think is the connector, its a 4 pin with or/blk, grn/wht, ylw/blk, and solid white. The harness looks to be from a ex since its prewired for vtec and there is no 7 wire plug for the o2 (the shell is a vx).
So I'm gunna have to put a o2 bung in, where do I put it? And what o2 sensor should I get? (meaning for what car?)
Old 03-29-2012, 01:05 PM   #21
Maybe im blind but didn't see if you mentioned the cel being on?
Basik_One is offline   Reply With Quote
Old 03-29-2012, 04:02 PM   #22
No its not on and yes it does work, I don't get it...this is why I'm bewildered about this...
Old 03-29-2012, 04:59 PM   #23
185 is a little low, did you actually do a leak down test or just compression test?
SteelcityLude is offline   Reply With Quote
Old 03-31-2012, 02:00 PM   #24
Really? 185 is low? I ask because ALLDATA says Usdm h22a1 should be from 135-185psi. This is why I assumed they were good numbers, not to mention the fact they all read 185 excatly. I would think it would be a heck of a coincidence that all 4 cylinders have the same amount of leakage. Just for arguement sake, let say I have a bent/chipped/warped etc. valve, that would be a mechanical failure which would show the symptoms constantly, which its not. It only acts this way when warmed up, when a car is at operating temp. It goes into closed loop which is when the sensors etc come into play. this is why I am almost positive its is a sensor/ ecu problem.
With that said, I have some new discoveries to share. I went to the junkyard yesterday and surprisingly found a complete, stock, VX hatch. What I noticed was the MAP sensor shares the same part number as the one in mine, are the MAP sensors more or less universal or could that be a potential problem?
Also, I opened up the ECU jus to find out anything about the chip....its a SST 27SF512. I did a little research on it and found that it is a reprogramable chip. What would I need to just put a stock h22 basemap on it?
Old 03-31-2012, 02:32 PM   #25
4.8t's Avatar
did you replace the stock coil when you done the tune up? i had an issue like this. it would miss under heavy load and run fine on light loads. as the engine heats up so does the coil. if its goind bad it will show more when hot. kinda like a starter going bad.
4.8t is offline   Reply With Quote
ek gsr idle problems and weird noise ekcid97 All Motor / Naturally Aspirated 13 10-18-2010 12:23 PM
single cam v-tec swap ej2kid17 Honda Civic / Del Sol (1992 - 2000) 3 04-10-2009 07:20 AM
Need help with p28 ECU!! FRKWOO Honda Civic / Del Sol (1992 - 2000) 14 02-28-2009 03:34 PM
Idle problems! Help please! b18b in ek pmpm06 Honda Civic / Del Sol (1992 - 2000) 11 01-13-2008 03:25 PM
GSR issues...no power...rough idle B18C1NMotion Tech / Misc 11 12-08-2007 04:32 PM
Tags
accord, acura, chipped, cuts, driveability, driveabliity, ecu, fuel, hitting, honda, po6, problems, pump, tl, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
