Dpfi to mpfi injectors not firing help! - Honda-Tech
Old 03-14-2017, 12:03 PM   #1
Default Dpfi to mpfi injectors not firing help!
Alright I am new to this site just trying to see if any of you guys on here can maybe help me out I just converted my 91 civic DX to mpfi put a jdm D16A motor in it got a 95 civic intake manifold and throttle body the wiring for the dizzy and injectors was pretty simple moved the two wired for the tps and had my I injectors ran to a resistor box which I then removed because I was told I did not need from someone very reliable. Im running a pm6 ecu. Grounds are all good I'm getting spark have 12v to yellow/black wired on injectors pulled the fuel rail off injectors are not spraying then two of them poped off and fuel went everywhere awesome right
Anyone able to enlighten me on this I would really appreciate any advice need my wheels back!
Thanks.
Whystherumgone? is offline   Reply With Quote
Old 03-14-2017, 11:09 PM   #2
Default Re: Dpfi to mpfi injectors not firing help!
What distributor are you running ??? From what application ??? If you are using the fuel injectors from the '95 Civic intake manifold, then you do not need a resistor box. However, your ECU and distributor MUST be in the same family to work. The PM6 ECU is OBD-0, so you would have to use an OBD-0 distributor as well to make this work. Fuel injectors from another family will work, but their latency will make the car run poorly at idle and low throttle loads... nothing a proper tune can't fix, but a stock ECU cannot accommodate the change.
JRCivic1 is offline   Reply With Quote
Old 03-15-2017, 02:19 AM   #3
Yes I am using the injectors out the 95 and you say I don't need the resistor box also so thanks that's settled
And both my pm6 ecu and my distributor for a 90/91 crx/civic si and the dizzy is brand new just bought it
Old 03-15-2017, 05:11 AM   #4
And thank you for the reply
DX MPFI harness in CRX SI? HBK Honda CRX / EF Civic (1988 - 1991) 3 01-12-2006 01:59 PM
please help MPFI Racersky Honda CRX / EF Civic (1988 - 1991) 4 01-07-2006 11:59 AM
DPFI to MPFI Problem need help!!! eghatchomar Honda CRX / EF Civic (1988 - 1991) 5 10-21-2004 08:47 PM
help on mpfi conversion.......... 904drlx Honda CRX / EF Civic (1988 - 1991) 5 06-01-2004 10:09 AM
Mini me help (injectors) s2kkk Honda CRX / EF Civic (1988 - 1991) 1 02-16-2004 06:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
