The Definitive Guide to a GSR-EG Swap!
Old 02-01-2012, 10:33 AM
  #51
ekkidd91's Avatar
Default Re: The Definitive Guide to a GSR-EG Swap!
**add to favorites**
bumpp
Old 06-09-2012, 07:44 AM
  #52
racingguy's Avatar
swapping a b18c1 motor into a del sol. new at this. i work with subarus and nissans. doing this for buddy. his motor is in. he had someone els wire it up. weare trying t6o get the motor running before we hook the cool system and other stuff up. motor will start as long as you prime the system. the more times you turn the key to prime it the longer the car will idle. then it dies. and it dies hard. and ends uip back blowing exhaust out the throttle body cause the air filter not on. it idles fine. you can rev it and it revs fine but then dies quicker. it seems its not keeping proper fuel pressure to keep the injectore sprayingproperly. and sometimes it cranks fast and easy but then it wont start. other times it turns over hard and thats when it starts. it is only off by one tooth. i re set the ignition timing. any other suggestions?
Old 06-09-2012, 07:48 AM
  #53
The Grumpiest
grumblemarc's Avatar
What?!
Old 06-09-2012, 08:08 AM
  #54
racingguy's Avatar
we are trying to get the motor running fully before we hook the cooling system up. its just the motor, the transmission, and the electronics in to. like i said. it will start. but wont stay started. need to prime the fuel system to have it idle for like ten seconds before it dies hard and makes a wheezing sound
Old 06-09-2012, 08:15 AM
  #55
The Grumpiest
Well, looking over the guide I clearly see where he states to hook EVERYTHING up and follows up by saying to check the timing.
Old 06-09-2012, 08:21 AM
  #56
racingguy's Avatar
ok so i hook EVERYTHING up and then turn it over to see if it will stay started. their is no reason why right now half the time it turns over easily like it should and the other times it turns over hard and slow. well no reason i can think of.
Old 06-09-2012, 08:25 AM
  #57
The Grumpiest
And the car is not throwing any CELs while it's doing this? Should have started your own thread. This has NOTHING to do with this guide or any steps in it since yoou aren't actually following it.
Old 06-09-2012, 09:47 AM
  #58
racingguy's Avatar
im a new user i cant start my own thread for like 5 days so ya
Old 06-14-2012, 07:32 PM
  #59
JustaEgg's Avatar
Just have to say, one of the most helpful threads I've read. Answered a lot of questions I had. And a lot of good info to go over my eg that was swapped before I got it.
Old 08-10-2012, 12:52 AM
  #60
MeCrObS's Avatar
random *** bump
Old 09-16-2012, 08:44 PM
  #61
altran's Avatar
bump
Old 09-16-2012, 08:45 PM
  #62
altran's Avatar
would this guide work with 00 civic ex
Old 09-17-2012, 01:35 AM
  #63
Technical Hero
HondaPartsHero's Avatar
Similar but useThis guide for the mounts and wiring
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
Old 05-04-2013, 01:10 AM
  #64
lorenzo fa sho's Avatar
im doing a gsr swap into my eg but using a B16 head, would i need the b16 upper hose or the gsr?
Old 07-21-2013, 06:37 PM
  #65
boca's Avatar
Nice
Old 07-31-2013, 05:52 PM
  #66
jvincent93's Avatar
Is there something like this for a gsr into an ef?!
Old 11-01-2013, 06:44 PM
  #67
hatchback032's Avatar
Bump Sweet Sticky!!
Old 02-20-2014, 05:31 PM
  #68
EJ1-eric's Avatar
this write up is ****! thanks for taking the time to make it, i will be using it soon
Old 04-10-2014, 07:49 AM
  #69
mgrandmaison1's Avatar
so i have a b20vtec i just installed into my 93 civic si eg hatchback. I also have both O2 sensors (4 wire Bseries and 2 wire Dseries). My question is: is there a spot where i can plug my 4 wire O2 sensor into my wire harness wich is out of a 94 GSR. Or even a spot in my dash harness that goes straight to the ecu? My car originally had a d16z6 and i am currently using my stock p28ecu. I'd like to get this tuning going as its running now and i also have a wide band O2 sensor but im fairly new to the whole tuning thing. I just want to make sure everything is set up for it. Hope someone has an clue lol
Old 10-24-2014, 05:21 PM
  #70
jdmem205's Avatar
I have a 93 civic ex and I'm going to drop in a gsr. My stock motor is a d16z6. Will I still have to change out wiring to run the vtec solenoid etc?
Old 10-26-2014, 04:51 AM
  #71
Technical Hero
What ECU are you going to be using? Intake manifold? What year is the GSR engine?
If you use a chipped P28 you won't have to run any more wiring for VTEC, knock or the IAB's.
However if you use the GSR dual butterfly manifold (IAB's) you're going to want to preferably use the P72 ECU and run wiring for knock and the IAB's.
If the engine is OBD1 the rest should be plug and play. If the engine is OBD2 you'll want the OBD1 components or jumper harnesses to use the injectors, alternator and distributor.
Old 03-07-2016, 04:31 AM
  #72
gostlyman2's Avatar
Just did my swap, hood wont fit, my driver side mount is not upside down. Really not sure where I went wrong....
Old 06-21-2016, 07:53 AM
  #73
Premium Member
94 Civic Si's Avatar
Some great pictures in here - thank you!
Old 06-21-2016, 08:05 AM
  #74
Premium Member
Originally Posted by MeCrObS
Oh one more thing! Set your Ignition Timing!!!!!!
Here's a Link!
http://www.youtube.com/watch?v=sGzxCCaxDjI
What distributor did you end up using?
Old 07-18-2017, 01:00 AM
  #75
Caleb Tetley's Avatar
what kind of exhaust do I need to mount it to my 93 dx hatchback? Have a b18c1 swap in it already but they won't pass it on inspection even though my county in MO doesn't require emissions.Or do I just need to order it for the catback and exhaust tip and run 2 and 3/4th's to 3 inch just before the tip? Was told to order an n1 exhaust for it but was also wondering wether there was a better option out there, already geared out for the strip has racing radiator stripped down to bare metal on the inside, battery in the back with a switch, toggle switch for the radiator to let the engine warm faster before a run, power steering and pump removed,lowered to 3.2 inches,k&n cold air intake, its basically a 1500 pound go cart as is its sits now lol, want to get as much outta the motor as I can. only has 40,000 mile's on the motor and it was built in Japan before it got shipped here and put into the civic, so it's just now ready for a turbo but I would like to know if anyone knows of a kit that will allow a gsr full exhaust to just be mounted straight to the 93 dx, been looking **** up on this issue for 2 days
Quick Reply: The Definitive Guide to a GSR-EG Swap!
