J37a4 stand-alone setup in jet boat
Old 01-28-2019, 02:31 AM
Junker907's Avatar
Default J37a4 stand-alone setup in jet boat
I am sure this is a little different than most of the other swaps on here but really I am trying to get any info I can on the best way to make a j37a4 out of the 2010 TL sh-awd run basically on an engine stand....I also have a j35a1 that I picked up for a decent deal encase I wanted to go that route being older and less complicated.
For the j37 I basically just need a flywheel and starter no transmission because I will make and adapter straight off the flywheel...alternator and belt....wiring harness and ecu and I would like to get rid of the drive by wire if there is any way to sweat throttle bodies...I am pretty new to all this swap stuff so any info is appreciated....my goal is to be as simple and light as possible and right at 300hp
thanks for the help hopefully this can get me going in the right direction and maybe it will be simpler than I am thinking hopefully
Old 01-30-2019, 11:46 AM
hondamark35's Avatar
Default Re: J37a4 stand-alone setup in jet boat
to get one of these to run on a stand... you'll need to a fuel supply system; you'll need one of these kits though it may require some modification since it only applies to the older, pre-VCM J-series engines. i guess you could run a looped coolant system if you're just running for a few minutes. a battery.
Old 01-30-2019, 05:32 PM
Junker907's Avatar
Ya coolant/fuel/exhaust/battery that stuff is pretty simple I am more focused on ecu/harness options and also flywheel/starter options because I will not have the transmission on the motor....I talked to marked Motorsports and they said they can’t help me with the j37 just a j35 for 04 or earlier
Old 02-01-2019, 05:31 AM
I wonder if the easiest route for a starter setup wouldn't be a bell housing from a compatible transmission, trimmed down to a minimum to act as a mount point for the stock starter. the ring gear is part of the torque converter. if you get the flex plate and torque converter from a salvage yard and trim away most of the torque converter... you can always upgrade to something more elegant later, but that would get you going.
may need to get in touch with some of the other standalone suppliers like AEM and/or Haltech
Old 02-02-2019, 10:37 AM
Freedo_Civegra's Avatar
Or megasquirt
lkailburn
08-13-2004 12:48 PM
DC_andrew
08-05-2004 08:36 AM
4genaccordfreak
10
01-10-2004 10:30 PM
MaxBoost
06-30-2003 01:40 PM
xonn
04-02-2003 09:10 PM
Quick Reply: J37a4 stand-alone setup in jet boat
