d16y8 engine harness with no evap purge solenoid plug?
Old 11-01-2015, 06:39 PM
justinmaccc's Avatar
Default d16y8 engine harness with no evap purge solenoid plug?
2 weeks ago i swapped an obd2b b16a2 into an obd2a 98 ex. I bought a 96 ex d16y8 engine harness off of ebay and then an obd2a to 0bd2b jumper harness so i could retain my p2t ecu. I noticed that my engine was throwing a couple codes, one being p0450 which is an emissions related code and then i remembered that i hadn't put the charcoal canister back into the vehicle so i went to put it in and there was no plug on the engine harness that goes to the charcoal canister (apparently the charcoal canister on some of the 96-98 civics is on the fuel rail rather than behind the engine.) Has anyone else run into this problem? is there a bypass that will turn off the CEL? or do i have to tap into the ecu and run a two-wire plug? Ive looked at the pinouts for my p2t and can't seem to find the ground wire for the purge solenoid. Any help is much appreciated hopefully someone has had this problem before and fixed it rather than just trashing the canister all together
Old 11-04-2015, 01:06 PM
Default Re: d16y8 engine harness with no evap purge solenoid plug?
Bump
If nothing else, does anyone know how to wire the purge solenoid into the ecu? i can pull the plug off a car at the junkyard
justinmaccc
14
05-05-2023 01:58 PM
dwellz80
07-20-2015 08:00 PM
1wiperDude
20
11-12-2007 05:26 PM
guedo148
06-14-2007 11:12 AM
Eaglekper0046
09-27-2005 09:41 AM
Quick Reply: d16y8 engine harness with no evap purge solenoid plug?
