d16A1 obd0 to obd1 conversion questions
Old 08-03-2004, 02:07 PM
euy
euy's Avatar
Default d16A1 obd0 to obd1 conversion questions
got a couple of ?'s about d16A1 obd0 to obd1 conversion.
1. will i have to change the dizzy, if so any idea of what dizzy to use, non-vtec
2. do i need to change the injectors
reason for the swap:
-keeping the stock d16A1 in my g1 teg getting ready for boost
-conversion to obd1 to so i can run hondata
-its cheaper than going zdyne and less technical than doing home tuning...
thanks in advance,
-euy
Old 08-04-2004, 04:56 AM
civicjester's Avatar
Default Re: d16A1 obd0 to obd1 conversion questions (euy)
yes and yes.....thats the easiest way to do it......dont know if teggie obd0 harness plugs directly into obd1 computer though might have to do some re-wiring
Old 08-04-2004, 02:08 PM
euy
euy's Avatar
Default Re: d16A1 obd0 to obd1 conversion questions (crxjester)
thanks for the info. the obd1 ecu is not a direct plug in. i will be using a harness.
- will i need anything else with injectors? resistor box?
thanks again,
-euy
Old 08-04-2004, 07:15 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxjester &raquo;</TD></TR><TR><TD CLASS="quote">yes and yes.....thats the easiest way to do it......dont know if teggie obd0 harness plugs directly into obd1 computer though might have to do some re-wiring</TD></TR></TABLE>
Yes and NO. You will need to get the OBD1 distributor, but you will not need to change out the OBD0 injectors. My harnesses come with full detailed instructions for the install.
Jason
dr_latino999
236
03-28-2020 12:34 AM
jacoblytle
Engine Management and Tuning
06-25-2014 07:56 AM
projsectEF
07-25-2006 12:32 AM
t . b o z
07-12-2004 06:08 PM
Quick Reply: d16A1 obd0 to obd1 conversion questions
