CRX B16 alternator belt replacement....Help!!!
Last night i was driving and i heard a noise so i pulled over to find my alternator belt lost an entire rib all the way around, and the belt turned around in the opposite direction, ribs facing up!! I have never see this before,lol. The belt was nice and tight on there so i must have ran something over. But anyway, What honda belt should i use?
I need stuff from honda so i figured i'll get an oem belt
*UPDATE*
Well found out some info... belt lengths and all are 4 rib for jdm b16 in a CRX
90-91 integra-30.5"
99 civic si-30.5"
94 del sol-30.5"
98-00 integra-31"
I am going to try one of these at my local autozone incase it don't fit i can return it.
Duralast part number is 305K4
However they do stock the FOLLOWING part numers with corresponding lengths:
300K4 which is 30"
290k4 which is 29"
285k4 which is 28.5"
AT least i can assure one of these belts will work on the b16 in a crx
Once installed i will varify which belt length does infact work once and for all!!!
Modified by alscrx at 9:56 AM 11/10/2007
*UPDATE*
90-91 integra-30.5"
99 civic si-30.5"
94 del sol-30.5"
98-00 integra-31"
300K4 which is 30"
290k4 which is 29"
alscrx
15
03-25-2008 01:37 PM
JRZ88DX
16
11-13-2007 03:56 PM
teler86
01-20-2005 07:36 AM
