Complete OBD1 B18C1 into Civic VX Wiring instructions.
This thread is to end all of the confusion about wiring a USDM b18C1 into a VX civic using the VX shock tower harness connected to the GSR engine harness.
WIRING A 1995 OBD1 B18C1 INTO A 1994 VX CIVIC USING A USDM P72 ECU
LOCATE THE 6 PIN PLUG BELOW ON THE PASS. SIDE VX SHOCK TOWER
The wires are in the following order:
ORG/BLU BLU/GRN WHT/BLK
BLU/YEL WHT/BLU YEL/WHT
REMOVE THE FOLLOWING WIRES FROM THE 6 PIN VX PLUG
ORG/BLU - O2 SENSOR
BLU/YEL - KNOCK SENSOR
LOCATE THE 10 PIN PLUG PICTURED BELOW THAT IS ON THE VX SHOCK TOWER
BRN/BLK EMPTY BLK/RED
ORG WHT ORG/BLU WHT/BLU
BLU/GRN BLU/YEL EMPTY
REMOVE THE RUBBER PLUG FROM THE TWO UNUSED SOCKETS
INSERT THE ORG/BLU (O2 SENSOR) WIRE INTO THE SOCKET BETWEEN THE BRN/BLK WIRE AND THE BLK/RED WIRE. (TOP CENTER SOCKET IN PIC)
INSERT THE BLU/YEL (KNOCK SENSOR) WIRE INTO THE SOCKET NEXT TO THE OTHER BLU/YEL WIRE. (BOTTOM RIGHT SOCKET IN PIC)
NOTE - IF YOU ARE USING A CHIPPED P28 ECU YOU WILL NOT NEED TO WORRY ABOUT WIRING UP THE KNOCK SENSOR
YOUR NEXT STEP IS TO MOVE THE RED WIRE ON YOUR ECU HARNESS FROM A20 TO A17 FOR YOUR SECONDARY RUNNERS FOR YOUR INTAKE MANIFOLD. THEY SHOULD OPERATE AS SEEN HERE .
ALL YOU HAVE LEFT YOU DO IS PLUG IN YOUR ECU AND PLUG THE 3 VX SHOCK TOWER HARNESSES INTO THE GSR MOTOR HARNESSES.
If you have any questions PM me.
Modified by dwnthehatch at 10:51 PM 11/12/2004
ORG/BLU - O2 SENSOR
Last edited by dwnthehatch; 08-28-2012 at 03:13 PM. Reason: Uploaded old pics since I still get asked how to do this.
Re: Complete OBD1 B18C1 into Civic VX Wiring instructions. (eghead)
Can you tell me how to rewire my 96 vx coupe o2 sensor 5 wires to a 4 wires? I'm getting a code 41 (primary o2 sensor heater). The car has an ls/vtec with the obd2a-obd1 conversion harness. I tried to wire the 4 wire o2 sensor directly to ecu and still get the code. Will you know about this problem? thanks a lot.
Vic
Vic
Re: Complete OBD1 B18C1 into Civic VX Wiring instructions. (wannaTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR »</TD></TR><TR><TD CLASS="quote">would it be possible to post up the second picture of the 10 pin plug cuz thatd be awesome, thank you</TD></TR></TABLE>
That would help me a great deal as well... I don't think imagestation allows you to remotely post piqs anymore unless they changed their policy again.
Re: Complete OBD1 B18C1 into Civic VX Wiring instructions. (dwnthehatch)
DO you know any thing about a '97 JDM B18C OBD2 into a '92 Civic VX using the OBD2 ECU.... wiring wise I mean ?
Re: Complete OBD1 B18C1 into Civic VX Wiring instructions. (dremmel)
What engine is in a '94 VX?? (Im in Ireland, our models are different)
i.e. What CC, is it MPFI(multi-point-fuel-injection)? and is it OBD1 or OBD2?
Just wondering as Im trying to find info to help with the wiring for my swap: OBD1 '95 JDM B18C1 into '96 Civic hatch 1.4sohc(MPFI) Non-Vtec(also OBD1).
Great info man, now im trying to drop in a Jdm d15b into my 92 vx (currently d15z1) what mods would i have to do to the wiring harness and can i use my existing ecu????? Thankz
Location: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">This thread is to end all of the confusion about wiring a USDM b18C1 into a VX civic using the VX shock tower harness connected to the GSR engine harness.</TD></TR></TABLE>
now.. what about wiring a VX long block, with the VX engine harness with a P28 running managment?
i basicly want to turbo my VX motor with the VX wirring and run a P28.
Re: Complete OBD1 B18C1 into Civic VX Wiring instructions. (Built B16A)
still no help about using the VX harness with a P28 ECU.
New User
"YOUR NEXT STEP IS TO MOVE THE RED WIRE ON YOUR ECU HARNESS FROM A20 TO A17 FOR YOUR SECONDARY RUNNERS FOR YOUR INTAKE MANIFOLD. THEY SHOULD OPERATE AS SEEN <U>HERE</U> ."
can you get this part working again ?? thanks trying to wire my secondaries up. after i switch a20 to a17 thats it ?? thanks alot
Re: Complete OBD1 B18C1 into Civic VX Wiring instructions. (whiteb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteb16a »</TD></TR><TR><TD CLASS="quote">"YOUR NEXT STEP IS TO MOVE THE RED WIRE ON YOUR ECU HARNESS FROM A20 TO A17 FOR YOUR SECONDARY RUNNERS FOR YOUR INTAKE MANIFOLD. THEY SHOULD OPERATE AS SEEN <U>HERE</U> ."
That's it.
To view the video just right click on the link and choose save target as...
It should work.
That's it.
It should work.
ok, i have the P28 chipped with uberdata, and its running like complete ***, cuz ims till running the stock Z1 harness and O2.. last night, i let it run for a while, and it was sputtering, and going up and down like it had a vaccum leak. long story short, i unplug the O2, and it stops.. plug it back in, and back to jacked up..
so today, being the cheap skate i am, i went and got a bosch O2 for liek 60 bucks.. it has 4 wires, 2 white, and 1 black and 1 grey.
black is signal, grey is ground, and it says white should be 2 additional heater elements? what pins should i be connecting these to?
help a brother out.. i have the P28 in.. now i have my 4 wire placed on the downpipe, and i want to hard wire it into the ECU.. what goes to what?
hey i just saw this and i have already switched the two wires on the shock tower harness, so according to this all your saying i have left to do is switch the red wire on the ecu plug, IS that correct? IS this all the wiring i have to do to make the engine run correctly without CEL. thanks
I would pm you but i'm a new user and can't use that yet.
Re: Complete OBD1 B18C1 into Civic VX Wiring instructions. (drtyhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drtyhatch »</TD></TR><TR><TD CLASS="quote">hey i just saw this and i have already switched the two wires on the shock tower harness, so according to this all your saying i have left to do is switch the red wire on the ecu plug, IS that correct? IS this all the wiring i have to do to make the engine run correctly without CEL. thanks
I would pm you but i'm a new user and can't use that yet. </TD></TR></TABLE>
That is all the wiring you need to do if you are wiring a OBD1 B18C1 into a VX.
