CIVIC SR3 (EG) RWD Conversion Build with SR20DET (many pict)
hello everybody...apologize in advance if there is a sentence that is less pleasing, because my english is poor
i am THAUVIEL from Indonesia, I was one of many enthusiasts CIVIC SR 3 in my country. Now I'm trying to bring something different from my civic.
I was with my bro STEVE PRAMUDITA (steve is a SHIFT engineering workshop owner, Yogyakarta-Indonesia) has a "crazy" plan for our civic. lol
we want to convert our civic into the RWD (Rear Wheel Drive) with nissan SR20DET engine
maybe it's first "crazy" CIVIC SR3 RWD in my country.
Our inspiration is from first Civic SR3 RWD from Japan with Honda F20C engine (S2K engine) and we trying to make something different with nissan engine.
Our purpose is actually just wanted to drifting with our civic.lol
Before making "crazy" civic, we've swap the engine into B16B
With turbo,but before the engine was started, the "crazy" idea has came. hahaha lol
And now the SR20DET engine for our CIVIC has come
READY TO CUT OUT!!!
Cut the wall and floor for gearbox
Make new wall and front-cross member with custom mounting for the SR20DET
The tunnel
The differential from Fairlady Z32 (R230 diff)
Cut rear floor
Custom rear undercarriage
New custom frame for the diff
HKS Hyper D for rear suspensions
Custom raw front lower underbrace + cusco strut caster adjustable
Make a tunnel cover
Roll cage for safety and stick at the ground
With new rims
Ready to painted the CIVIC
And who is busy with his handphone is my bro Steve Pramudita - the "crazy" man (peace bro ) with a lot of crazy ideas and the Owner of Shift Engineering Workshop
Custom front tube
Looks behind
Time to clean up the SR20DET
With SR20DET Greddy Intake
Some upgrade parts
Camber Plates
SR20DET Short Block with F1 Racing Stage 4 clutch kit
After finished the painted and cleaned,we install the SR20DET into our CIVIC
Custom E-Brake
Some upgrade parts again
START THE ENGINE
YEAHHHHHHHH, REAR WHEEL WAS SPINNING
Steve has tuned the basemap for our CIVIC
but the OEM turbo has damaged
Now we have prepared a new differential with Cusco 2 way LSD from skyline R33 with some modifications again and replace the damaged turbo with Garrett GT2835R and also replace the engine management system using Haltech PS1000 + wideband o2 sensor
While the project until there and will update soon
LOOKS CURRENTLY
you can check the video (first start with SR20DET) our civic at
THANK YOU
Thauviel - Steve, SHIFT Engineering - Yogyakarta, Indonesia
READY TO CUT OUT!!!
The tunnel
Cut rear floor
Make a tunnel cover
With new rims
Custom front tube
Looks behind
Some upgrade parts
Camber Plates
Custom E-Brake
START THE ENGINE
LOOKS CURRENTLY
THANK YOU
Re: CIVIC SR3 (EG) RWD Conversion Build with SR20DET (many pict)
WOW!!! That's a crazy build. That cage looks a little over done, no?! Haha either way this is a crazy unique build.
I say change the color (one solid color) and keep the rims shiny!
the painter is not good, and we will change the color soon after the undercarriage and engine is running better...
Looks super badass. You need some hotdogs to go with all that ketchup and mustard! (this joke will probably be lost in translation, but oh well)
andycivicfan
05-01-2007 02:39 PM
