BIG PROBLEM need new motor mounts for H22A EG but stock locatation cut off
OK i bought a 1994 civic hatch with a h22a in it and its been non stop problems... i bought HCP motor mounts to replace the homemade ones that came with the car but the problom is the HCP mounts use the stock mounting locatation for the passanger side mount this is a MAJOR problom for me because the people who swapped this motor CUT THAT OUT.... all that holds the passanger side in on my car is the 2 small bolts that go under the frame rail originally used for the lower trans mount on the stock motor
I have no idea how to get that missing mount piece...
any help would be great
also i have a 1995 honda hatch with a stock motor in it i am contemplating cutting out its mount and using that not sure yet
DYNO-PRO
Location: SoCal I.E 909, CA, where we innovate not immitate
Re: (92hybridAccord)
you can order the "crash mount " for the pass side from your local honda dealer its cheap then you should be able to see where it was originally wels it back and use your bolt in mount kit
Re: (HOOKUPS)
AWESOME great idea i didnt think that honda would have that and its called the crash mount good stuff... How hard is it going to be to do all of the motor mounts does the motor have to come out or can i just suspend it??? On GSR we just suspended the motor but that was for a B series which is a lot smaller??? Regardless thanks for recommending honda I never honestley thought of that being a place i just figured junk yard or my other car...
Thanks
Thanks
Re: (allwhitehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allwhitehonda »</TD></TR><TR><TD CLASS="quote">AWESOME great idea i didnt think that honda would have that and its called the crash mount good stuff... How hard is it going to be to do all of the motor mounts does the motor have to come out or can i just suspend it??? On GSR we just suspended the motor but that was for a B series which is a lot smaller??? Regardless thanks for recommending honda I never honestley thought of that being a place i just figured junk yard or my other car...
Thanks</TD></TR></TABLE>
It's under the "bulkhead" section on the parts catalog, and that framerail bracket only costs around $25. Get it, weld it in, and you're good to go.
Re: (RotiEatter)
you asked what other problems i was having with the car. well besides the motor mounts. The car dosnt idle even with the idle turned up all the way IN FACT adjust the idle DOES ABSOLUTLEY nothing. So I had to adjust the idle with the throttle cable adjustment. Also when I start the car black **** comes out the tail pipe and onto the drive way and makes a nasty mess... However the car dosnt blow any smoke after its warmed up. I am going to test compression soon to see if it blow by but I am hoping not and actually doubt that is the problem. Also i run check engine lite 43... It could be a wiring issue or it could be a bad o2 sensor its one or the other because the o2 sensor dosnt give a good reading. There are a lot of other small problems and major problems that I am dealing with but those are key right now... OH ALSO I need a stock prelude program so that I can re-program the chip thats in the ecu... Someone did custom tuning and I dont trust it ESPECIALLY since the REV limit is set to 8k and thats not cool to me...
DYNO-PRO
Re: (allwhitehonda)
this is why i recc a bseries anyways do you have the aic valve wired correctly? does your manifold have a fast idle valve underneath the t-body?
Re: (HOOKUPS)
i am not sure if it has a fast idle valve or not? i wouldnt even know what i was looking for... there seems to be a plug that is not plugged into a sensor but i cant find a sensor for it might have been something in the stock vehicle that i dont have anymore
some people have recommended cleaning the iacv and seeing if that solves the problem... also people have recommended jump the service connector and disconnect the iacv to see if the idle changes? I plan on trying those things and also going through some more wiring tomarrow. It has nothing to do with the fact that its a H22A its all the fact that its poorpley installed and tuned...
also How do i find out if it has a fast idle controll valve? any other suggestions for fixing my idle problem would be appreciated
thanks
william murphy
thanks
william murphy
SoullessJapaneseMachine
16
12-24-2020 07:11 PM
rocketfuelcerx
01-21-2005 01:23 PM
