Best way to remove stuck hoses/connectors? - Honda-Tech
Old 09-20-2003, 12:58 AM   #1
GPoodle
Guest
Posts: n/a
Default Best way to remove stuck hoses/connectors?
My car is a 93' Civic thats lived its live through rain and salt in Wisconsin. I started the swap and NEED the motor out tomarrow (saturday) so that I can put the other one in and get the car out of the garage by sunday. Seriously like 90% of the hoses and wire connectors are ******* stuck on really good and pulling as hard as I can (without pulling on the wires) doesnt do anything. Is is safe to spray WD-40 on them or some other solvent (liquid wrench, PB blaster, etc)?
Also, whats the best way to get the hoses unstuck? Can I heat them with a torch? I really can afford and dont want to deal with cutting them so anything that'll help unstick it is best.
Thanks guys, this sucks.....
Old 09-20-2003, 02:06 PM   #2
inspyral's Avatar
I usually pry carefully with a screwdriver.
inspyral is offline   Reply With Quote
Old 09-20-2003, 03:53 PM   #3
CvexH22's Avatar
Default Re: Best way to remove stuck hoses/connectors? (GPoodle)
I use pliers , one that is big enough for the hose. Firmly grip around the hose+pipe contact area, TWIST back/forth and pull at the same time.
CvexH22 is offline   Reply With Quote
Old 09-20-2003, 04:05 PM   #4
Sunrise City Rider's Avatar
always push the hose off, don't pull it as it will only grab onto the pipe even tighter...take a needle nose pliers and leverage it off...if you have to pull, then pull while leveraging it off...
Zee
Sunrise City Rider is offline   Reply With Quote
Old 09-20-2003, 04:48 PM   #5
Six2Six's Avatar
I Just cut mine off by splitting it and then peeling it back, I would rather replace the hose Than break something.
Six2Six is offline   Reply With Quote
Old 09-20-2003, 05:15 PM   #6
Kamin's Avatar
Default Re: (gildor)
giant pliers, grab around the hose, twist, then pull.
Kamin is offline   Reply With Quote
Old 09-20-2003, 08:58 PM   #7
New User
Newman's Avatar
Default Re: Best way to remove stuck hoses/connectors? (CvexH22)
Quote:
That's the best my IMO. I've seen (and done a few times) the other ways and some other methods, and the way above is the easiest and cleanest way, and the least amount of chance of ripping the hose or breaking the neck that it's attached to. It sucks when you break off the neck of an old radiator when you try to use a screwdriver or just try and pull the hose right off.... time for a new radiator.
Newman is offline   Reply With Quote
ED7 Build Thread 4cylJDMcrazE Honda CRX / EF Civic (1988 - 1991) 12 03-12-2014 11:54 AM
My EF Build Thread 4cylJDMcrazE Introduce Yourself 1 03-12-2014 08:46 AM
00 accord heat problem hondaaccordf23 Honda Accord (1990 - 2002) 4 12-13-2013 07:58 AM
Only one tire spinning on my 89' Civic Hatch? combos99 Honda CRX / EF Civic (1988 - 1991) 6 02-18-2008 07:08 PM
Emissions in wisconsin... Can I change my listed county so i can get out of emissions? T--Rex General Discussion and Debate 8 10-12-2005 09:43 PM
Tags
car, civic, connectors, easy, honda, hose, hoses, motor, pipe, pliers, remove, removing, stuck, trick, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
