Best way to fix a stripped block head stud hole (idk) - Honda-Tech
Old 01-06-2012, 07:08 AM   #1
Dioxine's Avatar
Default Best way to fix a stripped block head stud hole (idk)
Ok so i dont know what to call it. But the threads in the block where the head stud goes into are crossthreaded and stipped. What is the best way (if any) to go about fixing this. Or should i just trash the block and get new one. Thanx in advance.
Dioxine is offline   Reply With Quote
Old 01-06-2012, 05:43 PM   #2
Default Re: Best way to fix a stripped block head stud hole (idk)
M12-1.25 thread tap get it at your local auto store and hopefully it works but before you put the head back on put the stud in the hole that you fixed.
hondasdohc is offline   Reply With Quote
Old 01-06-2012, 05:49 PM   #3
per4mance's Avatar
Quote:
no, if the threads are stripped the material is gone. Best way to fix it is a time-sert or what is also known as an insert. Google it and that would be the best way and will last.
per4mance is offline   Reply With Quote
Old 01-06-2012, 06:02 PM   #4
Oh yea your right i feel dumb. Yeah get the inserts.
Old 01-06-2012, 06:36 PM   #5
Dioxine's Avatar
See thats what i was thinking, would they actually be able to withstand the pressure though without moving. Im worried that as soon as they get force on them they will start to pull out.
Old 01-06-2012, 06:38 PM   #6
Dioxine's Avatar
Ok so i just looked at that and ive never seen anything like that before, i was thinking something like a hetacoil that looks like it will be a lot better
Old 01-15-2012, 12:28 AM   #7
Time-set makes a honda head stud repair kit. We have it and have used it on damaged sleeved blocks that make over 650hp. It works great.
Divers is offline   Reply With Quote
Old 01-15-2012, 08:12 AM   #8
Dioxine's Avatar
Quote:
Do you know where i can find said set?
Old 01-15-2012, 08:09 PM   #9
It's pretty expensive (about $400) for only one block. If you don't want to buy it I can have Shawn send you a UPS call tag for your block and do it for you. PM me if interested.
Here's the link of said kit. Just google shopping search and they are all over.
http://www.timesert.com/html/honda.html
Head stud kit for LS-VTEC integraboosted Tech / Misc 2 08-26-2006 06:22 PM
ARP Head Studs for B18C1 Block with B16 Head. jsull. All Motor / Naturally Aspirated 1 01-24-2006 10:07 AM
Cross threaded a front Lug Stud :( 5spdIntegra Acura Integra 15 06-12-2005 08:09 PM
whats best for rethreading a block for the head studs the DA in HONDA All Motor / Naturally Aspirated 1 05-10-2005 10:16 PM
odd headstud torque dilemma //knowledge is needed boosted_zc Tech / Misc 2 08-19-2003 04:35 PM
Tags
12, 125, block, fix, head, headstud, honda, j32, kit, repair, stipped, striped, stripped, stud, studs, threads
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
