B20Z - CRV or B18C????
Old 12-24-2001, 03:26 PM
B18C-Hatch13's Avatar
Default B20Z - CRV or B18C????
I have a '95 CX hatch and would like opinions on which engine setup pto go with:
- B18C: Stroker, Full TODA spec B internals
- B20Z: B16A2 Head and full TODA spec B internals
The TODA will take a while $ and both are NA and they will be daily drivers
thanks
Old 12-24-2001, 05:12 PM
Default Re: B20Z - CRV or B18C???? (B18C-Hatch13)
top
Old 12-25-2001, 10:50 AM
Bert1's Avatar
If it were me, I'd have the B18c resleeved to 2.0 (or bigger.) If you don't want to do that, a B20 would be nice if done correctly (crank girdle, oil squirters, etc.) Of course it really depends on what your goals are... you'll need to be able to rev high safely to get the full benefit of the b-specs and be reliable. Revving a b20 bottom end or a stroked b18 to 9k would worry me.
[Modified by Bert1, 7:51 PM 12/25/2001]
Old 12-25-2001, 01:47 PM
Quick 200k Mile Motor's Avatar
Default Re: B20Z - CRV or B18C???? (Bert1)
race motor stroke it..
daily driven.. resleeve it.
Old 12-25-2001, 05:12 PM
New User
gsrvx's Avatar
Default Re: B20Z - CRV or B18C???? (Quick 200k Mile Motor)
Newbie here...but can you explain stroking/resleeving? Thanks.
-Rod
Old 12-25-2001, 05:25 PM
Bert1's Avatar
Default Re: B20Z - CRV or B18C???? (RK)
Depends on how in-depth you're looking to get. Cliff notes version: Both a stroker kit and sleeving + boring increase displacement. Stroking does so by lengthening the stroke (the distance the piston moves up and down.) Sleeving is done for greater strength and/or to allow the sleeves to be bored out to a larger diameter than stock, obviously increasing displacement.
Old 12-25-2001, 09:18 PM
New User
gsrvx's Avatar
Hey thanks. That clears things up for me.
Old 12-26-2001, 08:26 AM
Suprdave's Avatar
thanks
It's all about whether you Road or Drag Race and what your budget is.
The Toda B and C thrive in the high RPM ranges and that's exactly what you dont wanna do with a B20 unless it's built to hell.
Girdle, Internals, Balancing, Etc Etc Etc
Build a ******* GSR.
Suprdave
Old 12-26-2001, 09:28 AM
rainforest's Avatar
Default Re: B20Z - CRV or B18C???? (Suprdave)
bore and sleeve a b16a to a 1.8 then rev to hell. all the toda stroker kit is b16a rods and a gsr crank with toda pistons. and you lose your 1.74 r/s in favor for a 1.54 r/s . witch is lower than a gsr.
k20o2o4civic
03-01-2006 07:48 PM
TsukubaSpec
15
01-12-2004 06:35 AM
gamakichi77
56
09-02-2003 08:53 PM
carcala
12
09-18-2002 07:50 AM
Quick Reply: B20Z - CRV or B18C????
