J swap LSD options?
Old 09-16-2010, 08:58 AM
factoryhondaparts's Avatar
Default J swap LSD options?
First thing, I'm exploring a few ideas and I need to see if anybody has tried this.
1st assumption, as far as 6 speeds go, to get an LSD you would need an acura CL type S or TL type S 6 speed correct?
2nd assumption, it is easier/cheaper to get an Accord 6 speed, correct?
1st question, apart from the LSD how similar are these transmissions? Could you feasibly acquire just an LSD for Type S transmission and place it into an accord 6 Speed?
2nd question, If you could put a type S LSD into an accord 6 speed, how much would you be willing to pay for an OEM torsen LSD?
Any positive input will be appreciated.
Old 09-16-2010, 04:35 PM
splatV6's Avatar
Default Re: J swap LSD options?
There is another site called J32a.com, some one on there put a CL-S LSD on there 6 speed Accord.
If i find ill post it up for you.
Old 09-22-2010, 10:57 AM
rpm systems's Avatar
if your are look for a LSD but cant find a CL type-s tranny . use a 06 tl sport / navigation 6 speed tranny. has the LSD and you can still use the accord shifter and cables.
turbociv910
01-24-2014 09:06 AM
manchildteggy
Transmission & Drivetrain
05-01-2012 10:54 PM
spoonciv
Suspension & Brakes
08-22-2005 09:17 AM
mugen99
06-23-2004 04:48 PM
Quick Reply: J swap LSD options?
