b16a sir2 into an ek chassis
Old 06-23-2004, 03:37 PM
Grip's Avatar
Default b16a sir2 into an ek chassis
what mounts do i use?
what do i do about the harness?
what axels do i use?
thanks
Old 06-23-2004, 04:07 PM
Grip's Avatar
Default Re: b16a sir2 into an ek chassis (Grip)
ok i know what mounts to use
what axels?
what do i do about the obd1 engine wire harness and the obd2 harness thats in the car now?
Old 06-23-2004, 06:49 PM
pennies_hatchie's Avatar
1. same axles (any b-series axles from 92+)
2. use the dx wireharness from the ek and wire vtec manually or get a si wire harness. you also need to get a sensor (forget what its called) but its by the timing belt to make it obd2 OR get a conversion harness and run a chip p28
Old 06-24-2004, 05:36 PM
Grip's Avatar
Default Re: b16a sir2 into an ek chassis (pennies_hatchie)
thanks pennies_hatchie
im allready gonnna be using a jhpusa.com 96-00 obd2-obd1 conversion harness so i can run a katman chipped p28...what all do i need to do to run vtec?
Old 06-25-2004, 01:24 PM
Hockey27925's Avatar
the obd2-1 jumper harness may be good, but the obd1 harness wont plug into the driver side firewall, use ur stock harness n wire up the 2 wires for v tec and the knock sensor wire
Old 06-26-2004, 10:51 AM
JDM EJ1 95's Avatar
just did it in my friends 98 hatch.. ehh use the stock mounts . but use a SI rear tranny bracket.. you also have to use the drivers side bracket that comes on the engine but you can use your stock mount.. ahh we went to One6 for the wiring on the DX harness.. cost 100 dollars yhou should go over there if you dont have much experience.. but we used a jumper harness from Inlinefour.com and it runs great. everything is perfect.
One6 and everyone who works there bc they are helpful people.
Old 06-26-2004, 03:59 PM
Grip's Avatar
Default Re: (JDM EJ1 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote">just did it in my friends 98 hatch.. ehh use the stock mounts . but use a SI rear tranny bracket.. you also have to use the drivers side bracket that comes on the engine but you can use your stock mount.. ahh we went to One6 for the wiring on the DX harness.. cost 100 dollars yhou should go over there if you dont have much experience.. but we used a jumper harness from Inlinefour.com and it runs great. everything is perfect.
One6 and everyone who works there bc they are helpful people. </TD></TR></TABLE>
you dont need to tell me about one-6..i know everyone there and have done work for alot of them..im gonna be using hasport mounts,obd2-1 ecu harness,and the stock dx harness..ill just wire up vtec and knock..thanks
Old 06-26-2004, 08:02 PM
JDM EJ1 95's Avatar
Default Re: (Grip)
well soooooooooooooooooory i should bow to you lol jk.. i didnt know but thats cool.. Bump for you
shocker911
02-06-2011 10:50 AM
dthug
08-02-2006 11:47 AM
TGrant
04-19-2006 02:25 PM
racerline
02-24-2005 08:48 AM
Quick Reply: b16a sir2 into an ek chassis
