b16 coolant leaks
b16 coolant leaks
I have a very slight leak of coolant coming from my timing belt area. anyone know of anyproblems with gaskets or seals in the area? thanks for your time
Re: b16 coolant leaks (shackler)
anyone, it looks like it could be from my water pump but I have yet to take my accessory pulley off. any ideas? hopefully its not a crack in the block
I would pull the timing belt cover off and check the water pump. That would be the most likely culprit...
