alternator pulley interchangeability
Alright so I'm fed up with alternators on my H2b swap. I have the innovative h22 alt relocation bracket and am trying to find a "no framerail mod" way to mount an alternator. Balance shafts deleted.
Accord alt doesn't clear.
D series alternator doesn't fit the bracket.
H22 pulley is too wide
I don't want to have to bash my frame rail...
Can I swap any pulleys around? I know B doesn't fit F/H, but will D fit B, or even F? Will a b series Alt fit the innovative bracket?
My next idea is to swap the rotating assembly from a D series Alt to the F series housing....
Steve at Heart
Re: alternator pulley interchangeability
Are you running the innovative bracket at the 1/2" over position?
It was my understanding that an EF required more clearance. Assuming that the car in your avatar is the same you are refering too. Other option is sell your mount and alternator and pick up the ESP kit using a d series alt. or the QSD kit which uses a b series alt.
Do you have any pictures of the test fitment and alignment issues?
turtleman321
05-03-2010 06:32 AM
infamousALLMTR
06-03-2002 03:52 PM
