MEGASQUIRT( i want to try it for my k series build)
Old 04-09-2008, 01:44 AM
RS2 FAB's Avatar
Default MEGASQUIRT( i want to try it for my k series build)
so after reviewing/reading up and researching all the standalone ecu's. comparing their software/features.......... i decided to go the OPENSOURCE route.
the build is a k24/k20 into a 1993 civic ex coupe, hybrid mounts, and a wet nitrous shot
has anybody ever ran/played with megasquirt w/ a k motor?
also: before saying hondata's Kpro will be better........... not it won't. it is not even close to a standalone, and everybody should stop refrencing it as one.
a k pro unit is just an advanced piggyback, utilizing the stock ecu with a programable daughter board on the inside of the ecu to manipulate the stock honda code
if you guys did'nt understand any of that.........it just means that hondata's K pro IS NOT a standalone
Modified by RS2 FAB at 2:51 AM 4/9/2008
Old 04-09-2008, 07:46 AM
SIXTY's Avatar
Default Re: MEGASQUIRT( i want to try it for my k series build) (RS2 FAB)
If you are familiar the system, go for it, why not? We used sds in the past on a b-series, the hardest part was trying to find someone local who knew how to tune with it.
Old 04-12-2008, 02:27 AM
alfa75ba's Avatar
Hi,
I have been using Megasquirt for 6 years now on my racing car and have been really satisfied. It is affordable, can be configured to work with various inputs and outputs, and you have control over everything, fuel,spark,boost...
My main concern at the beggining was its durability, but although I soldered this unit myself ( for few bucks more proffesionally built units are available) never had any problems with it.
One can change all parameters in real time, do datalogging (I datalog all my races), use O2 sensor feedback to adjust fuelling in realtime (I use it with wideband sensor even when racing).
Megasquit community is large and very helpfull and all info and answers can be found on Megasquirt forums.
I run it on Fiat engine (our racing Civic is still on Webbers :-) ,but principle would be the same.
Sorry if I missed the point, Drazen
Old 04-13-2008, 06:35 AM
jdm monkey tuning's Avatar
Default Re: MEGASQUIRT( i want to try it for my k series build) (alfa75ba)
how would you control the i-vtec?
with just vtec, there's no problem
Old 04-13-2008, 01:40 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS2 FAB &raquo;</TD></TR><TR><TD CLASS="quote">a k pro unit is just an advanced piggyback</TD></TR></TABLE>
not quite.. hondata products are basically rom editors (unless k-pro is different). Piggybacks manipulate signals going to the ECU (which is gay).
the fact that it is NOT a standalone but retains the oem functionality is a huge pro, not a con for most setups on here.
Old 08-18-2012, 10:51 AM
rpm systems's Avatar
well you ask for it . the a guy that got the megasquirt system to work on his k24 turbo setup. here is the video:
http://youtu.be/c9Tnl5IGE_g
now is where the fun begins.
Old 08-19-2012, 02:21 AM
eDm cRxXx's Avatar
Can they do dual maps?
And how do they do the VTC map?
forbiddenera
04-19-2018 07:26 AM
jksmith
11-19-2010 08:49 AM
03_acura_rsx
Engine Management and Tuning
04-13-2009 12:26 PM
Quick Reply: MEGASQUIRT( i want to try it for my k series build)
