92 jdm d15b (auto) into 91 usdm crx (manual) swap - Honda-Tech
Old 03-18-2017, 04:53 AM   #1
twincammy's Avatar
Post 92 jdm d15b (auto) into 91 usdm crx (manual) swap
Hi guys, looking for some advice on this swap. i have the chance of a complete jdm d15b Auto Delsol and fancy it do the swap into my crx DX.
obviously ive tried searching and theres a lot of info out there, but also a lot of dead links etc. besides i cant find any info on this exact swap....
basically the main items i need confirmed are
1.will the crx 5speed tranny bolt straight up? (research ive done seems to indicate yes)
2. will the auto ecu will be no use for the manual car? (research says a chipped p28 would run the d15b ok?)
3. i would have the two complete running cars, besides an ecu what else would i need?
apologies in advance for typical newbie type post, but i have tried searching..
twincammy is offline   Reply With Quote
Old 03-19-2017, 06:05 PM   #2
EG RussE's Avatar
Default Re: 92 jdm d15b (auto) into 91 usdm crx (manual) swap
Jdm D15b swap into ef
some good info about transmission
You will benefit alot more with a si transmission. Better acceleration.
id recommend converting to obd1
Po8 ecu would be great or a chipped ecu or hondata and tune
try searching d16z6 into a crx its a identical swap
EG RussE is offline   Reply With Quote
k24 auto swap paki Honda Civic (2001 - 2005) 1 10-20-2016 09:22 PM
2000 civic d16y7 to d16y8 generationdream Honda Civic / Del Sol (1992 - 2000) 3 10-01-2016 11:19 AM
D16Y8 to JDM D15B complete swap!!!! jordanscivic98 Honda Civic / Del Sol (1992 - 2000) 1 03-19-2011 09:37 PM
auto mpfi help. please tyler100 Honda CRX / EF Civic (1988 - 1991) 8 06-05-2008 07:19 PM
Doing an auto-2-manual swap... ? sparq Honda Civic / Del Sol (1992 - 2000) 14 01-29-2003 07:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
