89 si hatch with b18c1 ... no fuel or injectors...
89 si hatch with b18c1 ... no fire or fuel from injectors...
Ok, here is the deal, i am gonna call Rywire monday..see if they can help since they modified my engine harness.
But i have everything plugged in, all grounds hooked, firing order is correct,
its in time.
I have a obd1 gsr block, 1st gen b16 head, JG victorX manifold, sat. RC 550's, 3 bar spliced in.
I tried my p28 uberdata ecu, it was tested and i had the chip reburned, still no cel's ... just a solid cel... i tried a p28 i have with a skunk2 chip that i know works and same thing.
I have fuel at the rail... but none coming out of the injectors and no fire from distributor.
I have the Rywire distributor adapter plugs, vtec subharness and JKOBD obd1 adapter harness.
So any ideas... a local guy who knows ef's pretty well was supposed to come look at the wiring for me ..but he is no where to be found now.
Any help is appreciated... i am stumped completly.
Modified by TodaCivic at 10:02 AM 7/25/2005
its in time.
Re: 89 si hatch with b18c1 ... no fire or fuel from injectors... (TodaCivic)
Not tryin to insult your intelligence, but you have all your grounds hooked up right?The reason I ask is because this has happened to me on many occasions.
Re: 89 si hatch with b18c1 ... no fire or fuel from injectors... (Turbo88hatch)
Fixed, turns out i didnt have the ecu ground hooked up...it was wrapped up in some tape on the harness.
I feel uber stupid now.
But i have never put an engine harness on the car while the motor was in... learn something new everyday i guess.
TodaCivic
07-26-2005 06:59 AM
