00 civic with H22a. PS and AC?
Hi, I'm kinda confused. I'm in the process of getting an h22 swapped into my 00 civic 4dr. First off I would like to say that I want to keep all amentities I can. ie..AC/PS Now I more then sure I can get PS hooked up, but what about the AC? I know HCP sells the AC bracket but they told me that only in conjunction with there motor mounts. I bought HAsport mounts. So my question is does anyone know if I will still have the clearance/room to use the HCP mount so that I can have AC. Reason I ask is because I know different companies mounts set the engine at different angles and what not. I'm confused and don't want to waste the money buying the part if it won't fit. Let me know because alot of the places I call I can't get ahold of the people there. Thanks, Robert.
Re: 00 civic with H22a. PS and AC? (thatboyrob)
It will fit. A/C is not a problem, & power steering is also not really a problem in EK civics.
You need a 97+ power steering line to make it happen. You'll have very close clearance issues, but nonetheless will clear.
Other than that, you have it down..
VBitter
01-26-2011 08:34 PM
