[FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
Old 03-31-2005, 08:59 PM
  #1301
poison's Avatar
Default Re: (solk1dd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solk1dd &raquo;</TD></TR><TR><TD CLASS="quote">My check Engine light goes on everytime my car gets warms up.?</TD></TR></TABLE>
What is the code?
Old 03-31-2005, 09:01 PM
  #1302
poison's Avatar
Default Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (SprayinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX &raquo;</TD></TR><TR><TD CLASS="quote">is anyone running the integra cfs sensor on a h22 while running a obd-2 gsr ecu? if you are then how did you mount the sensor?
if i am not mistaken the sensors read different. such as the main timing belt piece that goes over the pulley shaft has the "arms" that it reads from.
i really have no idea how the h22 one works.</TD></TR></TABLE>
If you're referring to the CKF, you can eliminate the code or sensor by tricking the ECU. I can't remember the pinouts right now, but I will definitely post them up tomorrow. Just need to take a peak at one of the cars I did it to.
In other words, f*ck the CKF.
Old 03-31-2005, 10:43 PM
  #1303
solk1dd's Avatar
Civic/DC H22 Drivers!!!!
Is it just my car or what....?
I let my car roll at 1st then I hit the gas all the way... I barely get any traction on regular tires, at the same time my RPM Climbs Hella fast...Then I shift to 2nd after a while it starts getting traction then WOOHOOOO....my car starts pulling hella fast but my car seems to not go on a straight line unless I hold the steering wheel hella hard&gt; seems like its going left and right but in a long stretch.
Does this happen to you guys??
I have a 4 door integra w/ JDM H22A
I LOVED it tho It Pulls Hard. But I have to worry about holding the steering wheel hella hard to make it go on a straight line when I'm racing.
Any1 got any suggestions on how I could improve this?(suspension?TIRES? LSD?)
Old 03-31-2005, 11:36 PM
  #1304
AudioFuct's Avatar
thats called hella torque steer, slow down......
Old 04-01-2005, 03:11 AM
  #1305
patastinky's Avatar
Default Re: (AudioFuct)
loved it...? or HELLA loved it..?
same what audiofuct said, i had this same issue in my accord and it's alot heavier then the DC's and Civic's. likes to pull to one side.
YOu could also get the toe checked out, mine was off a bit because of my drop and after geting the toe/camber adjusted it helped a little bit
Old 04-01-2005, 04:23 AM
  #1306
Adam.'s Avatar
m2b4 &gt; you
Old 04-01-2005, 08:26 AM
  #1307
AudioFuct's Avatar
Default Re: (DarkKnight1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight1 &raquo;</TD></TR><TR><TD CLASS="quote">m2b4 &gt; you
i hate you....... jealous as hell..... you either were lucky and they had them in stock or you are far more patient then i am and waited.....
Old 04-01-2005, 10:51 AM
  #1308
marshun's Avatar
Default Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (marshun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshun &raquo;</TD></TR><TR><TD CLASS="quote">ok ok. i got a question!
i got a sensor on the housing of the thermostat. im using an obd1 usdm ecu. does this need to be hooked up? if so, where does it go? i dont see it on diagrams. im thinkin it can connect to the temp sensor on the head.
please help!</TD></TR></TABLE>
Old 04-01-2005, 10:57 AM
  #1309
skunked's Avatar
You should have a plug on your harness for that temp sensor on the thermo housing. That sensor is used for your dash temp gauge.
Old 04-01-2005, 11:03 AM
  #1310
hondaZvic's Avatar
Any1 got any suggestions on how I could improve this?(suspension?TIRES? LSD?)</TD></TR></TABLE>
its called control.
lol
Old 04-01-2005, 02:22 PM
  #1311
marshun's Avatar
Default Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (skunked)
so i am supposed to use 3 temp sensors? cause theres one near the back of the head, one on the side, and the temp sensor on the thermo housing.
right now the one's that are hooked up are the one near the back of the head, and the one directly on the side next to the single wire sensor.
where does it hook up to?
i dont see any pin outs for that in the obd1 h22 diagram.
Old 04-01-2005, 03:51 PM
  #1312
kholmes's Avatar
Alright, just did the h22 belt tensioner conversion to the manual h23 but now the timing belt wont fit. Its right there but is to tight to go on. Can I use the h23 cam gears?
Old 04-01-2005, 06:34 PM
  #1313
kholmes's Avatar
Default Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (kholmes)
Scratch that, the h23 cam gears cant be used cause the teeth are spaced differently. So were did i go wrong? Got all the parts off a 95 prelude h23.
Old 04-01-2005, 08:33 PM
  #1314
solk1dd's Avatar
Default Re: (patastinky)
I HELLA LOVE IT BABEE&gt;
BAWaaaaBAWAwhaaaaaaaaaaaaaaaaa!!!!!!!!
Old 04-01-2005, 11:13 PM
  #1315
kholmes's Avatar
So in the case I get the belt on theres no need to tighten the tensioner since the belt will be tight as hell to begin with. Right?
Old 04-02-2005, 12:45 AM
  #1316
solk1dd's Avatar
What Intake Fits H22 94 Integra w/ ABS?
without touching disdributor......
Old 04-02-2005, 07:44 AM
  #1317
AudioFuct's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solk1dd &raquo;</TD></TR><TR><TD CLASS="quote">What Intake Fits H22 94 Integra w/ ABS?
without touching disdributor......</TD></TR></TABLE>
This one does.........reading is fundamental........
click and scroll down
https://honda-tech.com/zero...ge=42
Old 04-02-2005, 09:51 AM
  #1318
patastinky's Avatar
Default Re: (kholmes)
it will fit, i 1st wrap around the crank shaft then the water pump, then the exhaust came and then the intake cam. Also don't tighten the manual tensior bolt just yet.. wait till after you have put the belt on . then tighten the belt.
Old 04-02-2005, 10:36 AM
  #1319
solk1dd's Avatar
1 Question,
Did any1 in here with DC/EG H22 Swap remove the 2 Long Bolts on the front part of the Cross Member??
Mine is removed, I just want to kno if any1 else did this and the reason why?
Old 04-02-2005, 10:45 AM
  #1320
kholmes's Avatar
The belt is at least a quarter inch to short. I dont see how I can get this on.
Old 04-02-2005, 03:05 PM
  #1321
marshun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">You should have a plug on your harness for that temp sensor on the thermo housing. That sensor is used for your dash temp gauge.</TD></TR></TABLE>
so i have 3 sensors?
also who has an h22 in their EK? maybe i could bother them with questions.
Old 04-02-2005, 05:56 PM
  #1322
solk1dd's Avatar
1 Question,
Old 04-02-2005, 07:51 PM
  #1323
SprayinCX's Avatar
also who has an h22 in their EK? maybe i could bother them with questions.</TD></TR></TABLE>
i am working on it. i think i have solved my ecu questions and now i am waiting for my mounts and axles to get here
Old 04-02-2005, 08:24 PM
  #1324
patastinky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kholmes &raquo;</TD></TR><TR><TD CLASS="quote">The belt is at least a quarter inch to short. I dont see how I can get this on.</TD></TR></TABLE>\
i have done 5 auto to manual tensior swaps on h22a's using the h22a belt and the h23/f22a manual tensior parts and everytime i got the belt on and it was a tight fit. honda has a speical part/tool that they make to make getting the belt on-over the cams alot easier. Maybe you should get that. Even though IMO it's a waste of money, because in the 5 times that i have done the swap i have never had a problem getting the belt on over the cams . . Good luck!
Old 04-02-2005, 09:07 PM
  #1325
kholmes's Avatar
Finally got the belt on. Its got to be the tightest ive ever seen a timing belt but it seems to be ok, thanx for the help.
Quick Reply: [FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
