[FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
Old 06-30-2009, 11:50 AM
  #3001
H22EG'z's Avatar
Default Re: [FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
aight cool, about the hoses.. prelude? or the .. um.... del sol/ Teggy hoses?
Old 06-30-2009, 12:18 PM
  #3002
djnikko's Avatar
I used prelude rad hoses, the bottom one was fine and fit with no modifications, the top one needed a little bit of shortening each end.
Heres my build thread on honda evolutions (a UK site). Ive tried to go into detail about the fiddly bits which I couldnt find anywhere else.
http://forum.hondaevolutions.com/vie...=92201&start=0
Old 06-30-2009, 03:42 PM
  #3003
H22EG'z's Avatar
also what are the "Legal" cat-back systems out there for a 92 hatch?
Old 07-01-2009, 03:27 AM
  #3004
djnikko's Avatar
I dont know about exhaust legality as im from the UK, we have the same emissions laws thoughout the whole of the UK. Im guessing its the decibels that are a problem? Just keep it the stock prelude pipe diameter and keep all the silencers in place or beef them up if you have to. You can also buy silencer inserts from ebay depending on your tailpipe design. In the case of emissions just keep the prelude CAT attached to the downpipe.
Old 07-05-2009, 11:14 AM
  #3005
sciamutanna's Avatar
Hi,
I' ve a HAsport EGH2 motor mount for the Civic EG but I' ve a big problem whit the axles.
I've buy the HAsport Stage 2 axlex but nothing, they are brake.
I want to buy the ESP motor mount, nothing use this mount?
They are a good mount?
What are the best axles for the ESP mount?
Thanks and sorry for my bad english.
Claudio
Old 07-13-2009, 11:37 PM
  #3006
ADR33's Avatar
hey guys! a 97 coupe with an H22....
since its a h22 i really dont know wat to look for on like if the swap was done right and stuff like that.... the guy said it was done clean by a local honda tunner guy...
can anyone help me? i would also like to know wat would be a good price for the car... cause i think hes asking to much.... it has i brand neew champ white paint job off its all shitty on the edges where the paint meets the other things... also the guy that painted it mesed up on the clear coat... its all dripped in some parts of the car... and i needs a new windshield and some rims.... (its on steelies)
thanks in advance
  #3007
ADR33's Avatar
thanks in advance
Old 07-15-2009, 04:23 AM
  #3008
chris.roland's Avatar
ADR33 you must be joking! Don't go for it unless the paint job and the cracked windshield are masking a perfect engine with no body damage... That's just ludicrous.
It's like the old joke... A man wants to buy a car from another, asks him: "Is anything broken?" The other man says "No, no, the airbag just needs replacing."
Gold.
  #3009
Gold.
Old 07-15-2009, 08:27 PM
  #3010
ADR33's Avatar
Gold.
well i ran the car and SH** its STRONG even in 5th. i was doing bout 80mph and i though i was doing like 60 or something... its a smooth ride... i barely stepped on it in 5th and i was picking up spd hella fast.... lol i loved the feel of it.....
but oh well the guy said hes not gonna sell it anymore... "his wife said 'they cant afford another car' and he has to many bills".....
Old 07-17-2009, 01:10 PM
  #3011
H22EG'z's Avatar
does anyone have the Innovative H22 into EG92-95 mounts? i got them with no instructions.. i'm assuming i remove the pass side and weld in place.. but they have screw holes in the back half.. do those line up with some pre-existing holes? or.. do i drill some?...
Old 07-18-2009, 10:16 AM
  #3012
the_wrench116's Avatar
what happend to all the informative pics???
Old 07-24-2009, 01:07 PM
  #3013
MikeW's Avatar
Has anyone ran the shift cables through the firewall instead of under the car and then up? I did a k series swap this way a few years back before karcept was around and i ran the cables through the fire wall.
Old 07-24-2009, 06:44 PM
  #3014
h22a4sol's Avatar
i just did the swap and i just drilled the two hole with the screws ... but i got hasport it looks like this
thats a h22 into a del sol .. i also had to trim a lil bit of the frame by that mount so the tranny wouldnt hit the frame ..
Old 07-24-2009, 06:45 PM
  #3015
h22a4sol's Avatar
as far as the shift cables through the firewall im not sure exactly where to put them threw.. do i have to make a hole in the firewall to get them in or is it precut??
Old 07-24-2009, 06:49 PM
  #3016
h22a4sol's Avatar
by the way this thread has helped me alot ive read through all 121 pages .. took like 3 days but i did lol .. i have a 97 h22a4 that i took from my 5th gen into my del sol.. the main problem i ran into was that i had to get a new distributor due to changing from obd2 to obd1 and somehow the timing got messed up so now im doing that and hopefully it will start..
Old 07-25-2009, 12:06 PM
  #3017
SL0WEGG's Avatar
Anyone know of an axle that is half an inch shorter than the 90-93 axle? Mine is binding now since i changed from HCP to innovative. But only on the passenger side.
Old 07-27-2009, 10:19 AM
  #3018
im doing a jdm h22 swap is there any reason i cant get an obd2 to obd1 adapter and just cut the obd2 plug off then use my complete harness from the motor???
Old 07-28-2009, 07:27 AM
  #3019
h22a4sol's Avatar
you can get a adapter for your ecu but good luck finding the adapter to plug the engine harness to the car.
Old 08-02-2009, 01:01 AM
  #3020
h22civicsedan's Avatar
i just finished my h22a swap on my civic hatch .. i did have this engine in a sedan before but i sold the shell and swapped it in a eg hatch i had .. ill show pics of both engine bays
this is when it was in the sedan
this is how it sits now in the hatch
Old 08-04-2009, 02:03 PM
  #3021
H22EG'z's Avatar
hey.. for the rear Motor mount.... does it have to be an h22 manual mount.. or can it come from an accord or something... my swap didnt come with a halfshaft or a rear mount bracket.. im kinda pissed,
Old 08-10-2009, 09:45 AM
  #3022
SL0WEGG's Avatar
I believe i have a 92-95 prelude vtec rear bracket. But for sure i'm using a 90-93 accord half shaft w/ 90-93 teg driver axle and 86-89 integra passenger axle. I found the axle cheapest at Napa autoparts.
Old 08-10-2009, 01:38 PM
  #3023
H22EG'z's Avatar
yea the halfshaft doesnt matter.. as long as your axles match up
Old 08-10-2009, 05:41 PM
  #3024
H22EG'z's Avatar
so i took my intake and exaust manifolds off, and the intake side is clean.. but the exaust side is rather dirty.. is there any way i can clean the exaust ports without having to take the motor apart, i know your not supposed to get anything down inside right.. so just wondering. OH.. and the header my car came with is a "Jasmina"??? or "Jasma" its a JDM h22 so i dunno if thats the normal one it comes with.
Old 08-10-2009, 09:08 PM
  #3025
carvers's Avatar
x2 where the vacuum diagrams and wiring schematics
Quick Reply: [FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
