[FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
#276
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote"> EGR Wiring Info
EGR lift valve solenoid
(The connector colors, From left to right) BLK/YEL and RED
Sensor Voltage - BLK/YEL - goes to A25
ECU trigger - RED - goes to A11.
is this right here the lift valve solenoid?? it's connected to the intake manifold, and it's the only thing that seems to resemble one.. any of u guys know? i tried comparing my car to my friends prelude, but he has a 99 and my swap is out of a 93 lude.. so i was thinking maybe the location on the lift solenoid was different from the 2.. on his lift solenoid there are outlets for 2 hoses on mine there is only one, but i thought since the solenoid is connected to the intake manifold it wouldn't need a hose to the im since it's connected. can anyone shed a little light on this maybe? maybe i'm completely wrong lol. oh i took a pic of mine and circled it in red on what i thought the valve was.
thanks
thanks
#277
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (D16A6_HF)
To be honest. I didnt even use that in my swap. Completely left it out. But i also didnt hook up EGR either. I removed the valve and put a stainless steel plate over the hole with a gasket and called it a day.
As a matter of fact. Take a look at the first page. Look at the pics that fastwanabe has of his IM and the surrounding area. That solenoid isnt even there. I used those pictures as my own example and just left it out.
#278
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (AudioFuct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct »</TD></TR><TR><TD CLASS="quote">To be honest. I didnt even use that in my swap. Completely left it out. But i also didnt hook up EGR either. I removed the valve and put a stainless steel plate over the hole with a gasket and called it a day. </TD></TR></TABLE>
Yes, he needs it. He is in CA. The stock location for 92-95 lude is on the driver's fender. I do not have time right now to read it all, I will post later on tonight. I have to get my friends h22a civic ready for the track tonight.
#279
Re: (turbogixxer)
Does anyone have a pic of what needs to be done to the trans bolt-taken off or trimmed or nothin at all? And what exactly has to be done to it?
#280
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6_HF »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>that sir is the purge valve.
#281
Re: [FAQ] H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote">that sir is the purge valve.</TD></TR></TABLE>
that's strange, but it's bolted onto the intake manifold as if it was supposed to be there.. it looks like it came that way from honda..
#282
Re: (1SICJDM)
#283
Re: (1SICJDM)
Figured it out{trans bolt} myself today. Got everything done today, but ran into a snag. The rear motor mount bracket has been cutt, so until I find a H22/H23(hint,hint!!) rear mt bracket I can't put my motor in. The shift lkg wasnt too bad. I had to trim mi console plastic and havnt figured out a way to mount the front of the plastic down yet. The shifter cable/hole is in the way-any ideas would be great. We completely un-loomed both harnesses and reloomed my stock harness. It took awhile but the harness is PERFECT. If anyone in AZ has that rear bracket layin around please im me... Later!!!!!!!!!!!!
#285
Re: (1SICJDM)
Well we finished the swap today. I definetly have some bugs to work out. It runs real rough and shakes extremely bad. Even when the motor was warmed up it just didnt feal like ther was any power! I am not sure whats wrong or where to begin? I tried runnin both the P13 and the P28. I also used the resister box out of a 90 teggy, dont know if that matters. the good news is it runs..
#286
Re: (nema741)
This may be a stupid question, but Im confused, maybe someone can help, I have a H22A4 OBD-2 (2001) engine I need to drop into my 95 civic ex. My question is, for the OBD-2 engine, do I use my stock civic wiring harness and ECU like this forum describes, or does that just apply to OBD-1 H22s? Do I Purchase the H22A4 ECU and use the H22s wiring harness? Any help would really be appreciated.
#287
Re: (BeyondTheCompetition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeyondTheCompetition »</TD></TR><TR><TD CLASS="quote">This may be a stupid question, but Im confused, maybe someone can help, I have a H22A4 OBD-2 (2001) engine I need to drop into my 95 civic ex. My question is, for the OBD-2 engine, do I use my stock civic wiring harness and ECU like this forum describes, or does that just apply to OBD-1 H22s? Do I Purchase the H22A4 ECU and use the H22s wiring harness? Any help would really be appreciated. </TD></TR></TABLE>simple. just use an OBD1 P13 or P28 with the stock wiring harness. You will need to change the injector clips and convert it to external coil. I suggest you use OBD1 injector with the resistor box because the motor will run lean running an OBD1 ECU with OBD2a injectors.
#288
Re: (turbogixxer)
I got my shifter assembly from a 93 accord, will it work ok with the swap?? Also will B series injectors work in the H22 instead of running a resistor pack??
#289
Re: (1SICJDM)
I NEED to know what I can do without-EGR,lift soli,etc... I have a P13 & a P28 and where I live there is NO emissions. PLEASE respond soon!!!!!!!!!!
#290
Re: (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote"> I NEED to know what I can do without-EGR,lift soli,etc... I have a P13 & a P28 and where I live there is NO emissions. PLEASE respond soon!!!!!!!!!!</TD></TR></TABLE>
Without it?
p28 does not use EGR, just dont use them, i have none of that **** on my and it runs fine
Without it?
#291
Re: (1SICJDM)
OK I checked the codes- I am throwin a 3(MAP) , anyone know of where I can order a MAP sensor??
Modified by 1SICJDM at 7:44 PM 1/26/2004
#292
Re: (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote"> OK I checked the codes- I am throwin a 3(MAP) , anyone know of where I can order a MAP sensor??
Modified by 1SICJDM at 7:44 PM 1/26/2004</TD></TR></TABLE>
Ill sell you one.
check your vacumm source or is your map on the throttle body?
which throttle body you using?
Ill sell you one.
#294
Re: (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote"> Does anyone have a vacuum diagram for a H22/EG ???</TD></TR></TABLE>
bah, you only need 2 vacuum lines...
fuel pressure and MAP...done
#295
Re: (1SICJDM)
Well it was definitly worth the hard work and here is the finished(Never Finished projects!!) product!
Modified by 1SICJDM at 8:46 PM 1/31/2004
#298
Re: (racerxfear)
Runs like a raped ape on steroids!! I have a traction problem as I am sure I am not the only one. I am runnin Falken Azenis with 30psi and still spinnin em like butter....
