**Official H2B Discussion thread **
Old 03-11-2015, 02:44 PM
  #20451
Linh.'s Avatar
Default Re: **Official H2B Discussion thread **
This is an older version without v bands.
Old 03-11-2015, 10:21 PM
  #20452
Steve at Heart
Bently_Coop's Avatar
^ i figured. Could be an option if someone wanted it modified.
Old 03-15-2015, 09:42 PM
  #20453
Dorkenheimer's Avatar
Linh, why you getting rid of the header? I'm going to go with a Whitfield as well. I was really curious to see what HP you made as I'm K2H as well. Is there a coating on that? The pics on their page look like all their headers are in a raw metal finished product. Kinda leaving it up to the buyer to coat it.....idk.
Old 03-15-2015, 09:59 PM
  #20454
Steve at Heart
^ Linh never ran the car with it. Base price starts at 699, coating and others will be extra obviously.
Old 03-16-2015, 07:30 AM
  #20455
Linh.'s Avatar
I would like to go k24/k20 if I can part my motor out. If you put in an order it will come just like the picture. You have to send it out to get coated. I have mines ceramic coated with copper coating in the inside. I'm not really sure if it makes a difference but I didn't want it to drive around with the header not coated.
When I had talked to Jason he was using RMF jigs. So this is pretty much a rmf header.
Old 03-16-2015, 09:20 PM
  #20456
How long ago was it you bought these?
I couldn't imagine him using anything besides those jigs, amiright?
I wouldn't wanna roll around with that header uncoated either. How much extra did the coatings run you? Bently, I was pretty much planning on that 700 starting price.....owie, lol.
Old 03-16-2015, 10:02 PM
  #20457
Linh.'s Avatar
I bought it about 5 years ago but I ended up moving to Florida. Lost interest in cars.
Send him an email ask him. I ended up paying 170 to get it coated. You can buy mines haha
Old 03-25-2015, 11:50 AM
  #20458
jdragon1974's Avatar
So quick question going from b series to h2b H23a BT, I have rdx 410 injectors can I use those on hte oem h22 fuel rail with out buying new top hats for the injectors?
Old 03-25-2015, 01:30 PM
  #20459
NVM found it, b,d and h all have 9mm for the stock fuel rail.
Old 04-02-2015, 06:17 PM
  #20460
Steve at Heart
This place is dead.
Fuel line and filter installed. Vise with a rag and box wrench is so much better than adjustable wrenches.
Old 04-03-2015, 07:39 AM
  #20461
Originally Posted by Bently_Coop
This place is dead.
Is that an inline filter you used?
Old 04-03-2015, 10:12 AM
  #20462
eg64u's Avatar
NICE! I HAVE NOT ORDERED MORE PARTS FOR H2B NECESSARILY BUT PULLED THE TRIGGER ON A SET OF 15X8 949 RACING WHEELS FINALLY. I WAS DEBATING BETWEEN RPF1S, KOSEI K1, AND THE 949S. I HAVE ALREADY HAD RPF1S AND KOSEIS DONT COME IN THE SIZES I WOULD LIKE SO 949 6UL'S IT IS! SHOULD BE HERE TUESDAY!
Old 04-03-2015, 02:36 PM
  #20463
1991_crxsi's Avatar
^^^STOP YELLING^^^ MY EARS. LOL
Old 04-03-2015, 11:50 PM
  #20464
Steve at Heart
Yes
-6AN KTuned filter, Vibrant fittings and hose and split motorsports inverted flare to -6AN adapter.
Old 04-04-2015, 04:04 AM
  #20465
1991_crxsi's Avatar
^ yea, looks very nice. I need to follow suit.
Old 04-04-2015, 12:35 PM
  #20466
Steve at Heart
1991- thanks man, it is easier and cheaper than it seems. I bought the pieces at Speedfactory and Kevin saved me on a fitting.
Old 04-04-2015, 03:47 PM
  #20467
1991_crxsi's Avatar
Good info. thanks.
Old 04-05-2015, 12:11 AM
  #20468
Love that fuel line Bently. Your line runs into the firewall like that, stock?
I'm looking at getting some of the hoses I need for my fuel setup. I'm going to run an inline filter, discretely mounted on the firewall. I want to get rid of that huge stock filter, ugly. Seem like it would be more appropriate to get the swap in and take measurements for line lengths, or could/should I just measure my OEM lines on my D series and make an educated guess on length?
Yeah, this place is pretty vacant. There's still a few of us that poke around though!
Old 04-05-2015, 09:43 AM
  #20469
Steve at Heart
I removed the stock filter setup and installed the split motorsport adapter, then put the ktuned on the rail and both fittings on loosely, pretty much eye balled how much hose to cut keeping in mind the clearance for fan switch sensor, also had to turn the coolant fitting, use a punch and a small amount of heat from a propane torch. Otherwise the 90° fitting and coolant fitting would have been fighting for space.
Honestly I think best way is to get the pieces and assemble when the engine is in. Its not exact science type measurement.
Old 04-05-2015, 07:11 PM
  #20470
Ah, I see that now. Man, that is a tight fit! And yeah I've been beatin around the bush on stuff to buy today for fuel. I think I'll just order an overkill amount of hose, just to be safe. I gotta cut my hardline and flare it when I pull my D16 out, and I'll probably cut it down low, so I'll use a lot more hose. Got do some internet educating and learn more about fittings and stuff. Fuel line is typically -6AN right?
Old 04-06-2015, 01:29 AM
  #20471
Steve at Heart
With the adapter in link below there is no cutting the factory line. I ordered it through ebay though from same company. Saves extra pieces and cuts some cost.
Fuel Line Adapter 6AN Male to M14x1.5 Female INVERTED FLARE [FLA1415] - $14.95 : Split Motorsports, Breaking-up the Competition!
Old 04-07-2015, 08:30 AM
  #20472
Does that connect where the hard line runs into the fuel filter?
Old 04-07-2015, 12:32 PM
  #20473
Steve at Heart
Yes
Old 04-07-2015, 09:31 PM
  #20474
Killer dude! That's a great find. Saves me from buying a 37 degree flare tool kit. Thanks Bently!
Old 04-08-2015, 06:30 AM
  #20475
Looks pretty tight, my teg will have to be different. The fuel line does not come out of the firewall, unless you hid it that way?
Quick Reply: **Official H2B Discussion thread **
