**Official H2B Discussion thread **
Old 04-18-2012, 11:43 AM
  #17651
SiR_Chris's Avatar
Default Re: **Official H2B Discussion thread **
Originally Posted by SL0WEGG
When are you getting tuned?
It's getting tuned now - although first they are modifying a brand new sump to emulate the Kaisenspeed version. So I'd say in 1week I'll have figures, at last
Originally Posted by YeeJ6
lower timing belt cover looks sick!
Thanks! Although I'm going to remake it out of Aluminium. The acrylic just bowed in the heat and started rubbing the crank pulley lol
Old 04-18-2012, 05:23 PM
  #17652
Tkay08's Avatar
I wanna know if this the right radiator for h2b? or do i have to get the civic? im sure this might be the right one.
http://www.mishimoto.com/honda-prelu...nce-92-96.html
Old 04-18-2012, 05:36 PM
  #17653
SL0WEGG's Avatar
Get the civic unit
Old 04-18-2012, 06:08 PM
  #17654
Ek Forever y0!
Libertariat's Avatar
Get the civic unit
Correct. Radiator's are chassis specific, not motor specific.
Old 04-19-2012, 04:11 AM
  #17655
SiR_Chris's Avatar
If you're worried about cooling, you can use a double width rad from the 4th gen Lude if you make custom brackets and you can also use the same NAPA hose 8325 (or 8235 I can't remember) FYI
Old 04-19-2012, 11:41 AM
  #17656
YeeJ6's Avatar
which USDM pan is compatible with an h23a blue top? A friend of mine just cracked her oil pan..
Edit: 8325 for that upper hose
Old 04-19-2012, 12:16 PM
  #17657
SL0WEGG's Avatar
I thought all the pans were the same? Well interchangeable?
Old 04-19-2012, 12:35 PM
  #17658
Ek Forever y0!
No, I remember reading somewhere just the other week that there is a USDM replacement for the oil pan on the H23A bluetop.
Lemme see if I can find it.
Edit, Found:
Originally Posted by ESP.net
F23A1 Oil Pan same part #
A Normal H22 Oil Pan will not work, I believe the pickup is longer therefore the H22 Oil Pan is too short and will not bolt up. Found out hardway purchased a new OEM H22 and no workkky...
Old 04-19-2012, 01:49 PM
  #17659
SL0WEGG's Avatar
Theoretically speaking, couldn't you just replace the pick up tube as well?
Old 04-19-2012, 01:57 PM
  #17660
YeeJ6's Avatar
F23a1 oil pan it is!
Old 04-19-2012, 03:32 PM
  #17661
CivicB18C1's Avatar
Is $295 shipped for 304 stainless, mandrel bent 3" exhaust a good price? Or keep shopping?
Old 04-19-2012, 03:42 PM
  #17662
Ek Forever y0!
Bolt on or weld on? And it's not bad.
Mine was $275 installed at a shop for 2.5"
VRS exhaust is having a blowout in the marketplace if that's not the one your referring to.
Old 04-19-2012, 04:27 PM
  #17663
CivicB18C1's Avatar
It's a weld on. And not the one I was talkin about. I'll have to take a peak. And I more than not want a weld on. Want to put all v band on it. Thanks
Old 04-19-2012, 04:28 PM
  #17664
CivicB18C1's Avatar
And I'm terrible at searching. If anyone finds their link, let me know. Thanks
Old 04-19-2012, 05:46 PM
  #17665
Steve at Heart
Bently_Coop's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/h2b-oil-pan-kaizenspeed-kstuned-com-2965242/
is the oil pan dead now? don't see anything on there webpage
Old 04-19-2012, 06:08 PM
  #17666
CivicB18C1's Avatar
where is this ??
Old 04-19-2012, 06:17 PM
  #17667
Ek Forever y0!
Originally Posted by CivicB18C1
where is this ??
Doh, nevermind. I misread a post in another thread.
They were talking about a header blowout sale:
https://honda-tech.com/forums/performance-45/%2A%2A%2A%2A-rmf-style-narrow-b-series-header-blowout-sale%2A%2A%2A%2A-2899374/
Old 04-19-2012, 06:19 PM
  #17668
CivicB18C1's Avatar
they still are pretty cheap. $250 shipped for a 3" stainless weld on kit.....
Old 04-20-2012, 07:18 AM
  #17669
DA is best's Avatar
damn i hope that they can make it for an ef also ^
Old 04-22-2012, 08:32 PM
  #17670
JustOneOrTwoPosts's Avatar
hey guys, check the main section of the Hybrid thread for a poll regarding custom h22 timing belt cover!
Old 04-23-2012, 07:50 AM
  #17671
b_series?haha's Avatar
just finished putting in my h2b in my eg hatch and i noticed the throttle cable isnt connecting right onto the h22 braket, whats needed to be done to get it working?
Old 04-23-2012, 08:10 AM
  #17672
SL0WEGG's Avatar
My bracket is flipped upside down. Post a picture.
Old 04-23-2012, 08:45 AM
  #17673
CivicB18C1's Avatar
hey, stupid question....are the oil pumps different from us to jdm h22's?
i need one, and found someone selling one cheap online. he says he bought it from honda for a usdm h22 and doesnt fit his jdm h22. has timing issues??
i thought they were the same. anyone know?
thanks
Old 04-23-2012, 09:28 AM
  #17674
SL0WEGG's Avatar
Iirc, only diff is between obd1 and obd2
Old 04-23-2012, 10:48 AM
  #17675
AllMtrRex's Avatar
thanks
obd2 usdm oil pumps are the same for years 1996-1997 (exception for some late 97's ) part number 15100-P5M-305
obd2 usdm oil pumps are the same for years (late 1997)1998-01 part number 15100-P5M-A01
Although the mains are different from obd1(50mm) to obd2(55mm) the crank snout is the same size and both oil pumps should interchange.(I've only used a 96' obd2 oil pump on a jdm 94' obd1 engine)
The 1996-1997 obd2 oil pump also used to be cheaper. It looks like that has changed now on a couple of online dealer sites.
Quick Reply: **Official H2B Discussion thread **
