**Official H2B Discussion thread ** - Page 706 - Honda-Tech
Old 04-16-2012, 06:43 PM   #17626
DarKStaR5's Avatar
Default Re: **Official H2B Discussion thread **
do you think the 550s will be enough injector for e85? Trying to make in the 260-270whp range
DarKStaR5 is offline   Reply With Quote
Old 04-16-2012, 06:47 PM   #17627
zuptidi's Avatar
I'd be iffy about that, looks like a unorthodox pulley; known to break oil pumps and other problems.
zuptidi is offline   Reply With Quote
Old 04-16-2012, 07:04 PM   #17628
SP GARAGE's Avatar
Quote:
I believe 750's would be more suited for e85
SP GARAGE is offline   Reply With Quote
Old 04-16-2012, 07:14 PM   #17629
SL0WEGG's Avatar
I'd be sketched out rocking a crank pulley that didn't have a harmonic balancer within it.
You could get close to that power. Just pump that base fuel pressure lol
SL0WEGG is offline   Reply With Quote
Old 04-16-2012, 07:15 PM   #17630
DarKStaR5's Avatar
yea thats what i was going to run was 750s but if the 550s would work i was going to scoop them up from you.
What crank pulley would yall recommend? I know for a fact a factory one will not work lol.
Old 04-16-2012, 07:16 PM   #17631
Ek Forever y0!
Libertariat's Avatar
Libertariat is offline   Reply With Quote
Old 04-16-2012, 07:21 PM   #17632
SL0WEGG's Avatar
I've been using a shaved oem pulley for a while. Krut has a euroR single row on his. That seems to be the general consensus as far as pulleys being used. I think I was at like 70-80% duty cycle when I was making 233 with 45psi base fuel pressure. Duty cycle might be less. To be safe, you can roll with some id725s or 1000s(I think jaywest is using these)
Old 04-16-2012, 07:27 PM   #17633
SP GARAGE's Avatar
I use ID 725cc and have made 280 and still had more to go
Old 04-16-2012, 07:45 PM   #17634
JayWest's Avatar
Fuel injector clinic 900s here
Might do some injector/fuel testing this year.
JayWest is offline   Reply With Quote
Old 04-16-2012, 07:51 PM   #17635
Krut's Avatar
Car fired up today, injectors were not getting power at first, rywire harness had a plug for what looked like it was meant for a resistor box (1 power wire and 4 for the injectors) had to snip the plug off and tap them all to that power wire, started right up after that
Krut is offline   Reply With Quote
Old 04-17-2012, 06:24 AM   #17636
SiR_Chris's Avatar
Well the Sol is FINALLY in for tuning
custom lower TB cover:
Suspension finally fitted:
SiR_Chris is offline   Reply With Quote
Old 04-17-2012, 06:36 AM   #17637
SL0WEGG's Avatar
When are you getting tuned?
Old 04-17-2012, 09:53 AM   #17638
Tkay08's Avatar
hMmm, that's what i thought. I knew the OEM pulley will have a problem with the belt going onto the alternator. I need a new belt since i deleted ps and ac. Where can i buy these items ?
Tkay08 is offline   Reply With Quote
Old 04-17-2012, 11:09 AM   #17639
YeeJ6's Avatar
lower timing belt cover looks sick!
YeeJ6 is offline   Reply With Quote
Old 04-17-2012, 11:37 AM   #17640
DarKStaR5's Avatar
I guess i should have specified..... The last time the motor went into the car we shaved the factory crank pulley down, but the top of the pulley hit the frame rail and i was not pulling the motor back out to bang in the side. So we decided to use a unorthodox pulley since it was smaller and im pretty sure thats what my problem was with the last motor. The pulley thats on there now isnt the same as i had before and is a different style, but was on the motor when i got it and was running fine.
I plan on beating in the frame rail to give me more clearance this time, so should i go back with the shaved down factory pulley?
Edit: keep in mind this is in an integra..
Old 04-17-2012, 11:50 AM   #17641
Steve at Heart
Bently_Coop's Avatar
I purchased a f20b pulley from steve at h motors that may be another option for you.
Bently_Coop is offline   Reply With Quote
Old 04-17-2012, 12:28 PM   #17642
turtleman321's Avatar
You should definitely bang the frame rail in and use a shaved oem pulley or f20b single row pulley moved in 1/2"
I am using a stock h22 shaved pulley, with qsd kit and hasport mounts in a crx. all i had to do was bang the frame rail for the alternator and crank pulley.
im using an explicit speed alternator bracket
turtleman321 is offline   Reply With Quote
Old 04-17-2012, 12:31 PM   #17643
DarKStaR5's Avatar
Looks like i need to go dig up the shaved pulley. Luckily i had no problems with the altenator clearing, its a little tight but no modification was needed.
Old 04-17-2012, 02:35 PM   #17644
DA is best's Avatar
Upper or lower?
DA is best is offline   Reply With Quote
Old 04-17-2012, 02:37 PM   #17645
Quote:
Originally Posted by DA is best View Post
Upper or lower?
Upper.
Old 04-17-2012, 02:51 PM   #17646
SL0WEGG's Avatar
There's really just one spot that you need to bang for eg/dc. So ez, better to be safe than sorry IMO. Especially since you killed some bearings last time with an aftermarket pulley. I'd be paranoid.
Old 04-17-2012, 03:03 PM   #17647
DarKStaR5's Avatar
Yea i was going to go ahead and bang that spot where the top of the factory pulley hit when the motor comes out. There was just no way to do it without pulling the motor last time and we were on a tight schedule.
Old 04-17-2012, 07:36 PM   #17648
Ek Forever y0!
Burned up my logic header today!
Old 04-17-2012, 08:19 PM   #17649
CivicB18C1's Avatar
Do I need to relocate my alternator lower,
Or will it work in the stock position? (in an Ek hatch)
CivicB18C1 is offline   Reply With Quote
Old 04-17-2012, 08:30 PM   #17650
Ek Forever y0!
My alternator is in the stock location.
Besides, any lower you would be in the way of the A/C compressor
Official Championship White ITR Picture Thread Cosworth Acura Integra Type-R 6046 02-15-2017 08:17 PM
Official Flamenco Black Pearl & Nighthawk Black Pearl ITR Picture Thread Cosworth Acura Integra Type-R 1875 02-10-2017 10:16 AM
► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc Jimmy Acura Integra 81 10-28-2016 11:43 AM
Full QSD H2B Ek write-up (56k No way in hell, over 65 pics.) Enjoy. 95turboeg Hybrid / Engine Swaps 200 07-27-2015 05:52 PM
third gear issue official discussion thread (3rd, grind, etc) - INCLUDES ACTUAL TSB from HONDA builthatch Honda Civic (2006 - 2015) 450 03-19-2015 09:30 PM
Tags
chasiss, clutch, crx, dc2, ef, effect, gude, h22, h2b, honda, hood, mile, prep, quarter, tilton, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
