**Official H2B Discussion thread **
Re: **Official H2B Discussion thread **
I'm using the evo kit. So I'm putting my h2b into an 94 EG, Had a d15B in it with an internal coil distributor... I have two distributors for my h22a... internal and external, do I need to run the internal distributor because I orignally ran an internal with the old motor?
finally got my car running right, intake cam was off by one tooth lol
http://www.youtube.com/watch?v=dcm4Y64ZkHk
so I was observing my car today and noticed my timing belt was kinda moving around a little too much for my liking. It kinda moves in and out. Perhaps i'm missing that washer behind my tensioner?
edit: Its kind dark lol sorry.
http://www.youtube.com/watch?v=D-uvcJ2MD84
I dont know what it is. I don't remember if i put that washer behind my tensioner or not.
(if the video doesn't work, give it some time. I just uploaded to youtubez)
I had the same problem bro it is the siplest ting on mine i was missing the timing belt washer behindthe crank pullie it is ment to keep the the timing belt from comming out of its place. ill see if i got one spare and take a pic so you can see
Thats weird. I don't recall there ever being one there .
I have the one that goes on behind the timing gear. I don't think theres supposed to be one in front. But then again, maybe something should be there since the balance shaft pulley isn't there anymore.
I'm not exactly sure how everything is setup once you move the crank pulley over 1/2" since I just took my belt off and left everything factory but if you look at this pic it looks like they have a little piece keeping the T-belt from walking on the crank gear (wouldn't this defeat the purpose of trying to move everything over 1/2"?) anyway, just something I noticed when looking through the pics on the QSD site.
That looks like the spacer that's supposed to be on the otherwise of the crank pulley. If I put my spacer like that. My pulley would rest on the framerail. I suppose I could just get another washer like the one on the rear end put it on the front.
I'm really 2slow
yes, that spacer behind the crank should go on the other side of the crank pulley. If it does not fit you need to modify it or make one out of the balance shaft gear. Also make sure you get another one of those thin washers that go behind the crank pulley to keep your timing belt aligned and from trying to slip off onto your crank pulley.
question guys: whos left on this site who is a reliable source for a chipped p72 with a p13 base map?
also if i run an obd1 p72 that is chipped do i need to run Peak & Hold injectors with resistance box or can i just use obd2 h22 saturated injectors with the obd1 72 without any resisters or issues?
Depends what injectors you run, so if you run the peak and holds you will need one, or you can just use the saturated ones without a resistor box
No it's not. All depends on type of injector you run if you're gonna need a resistor box or not. I have obd1 345's and resistor box if anyones interested.
thanks man.. really appreciate the help... now can anyone guide me as far as a reliable source for a chipped p72 w a p13 base map??
2 quick questions for those h2b setups out there...
my setup:
93 civic hatch si
H22a euro r
ITR trans
Evolution Ind. h2b kit
Exedy stage 1
h2b header from logic motorsports
My plan is too bolt on header and intake, tune and close the hood. Will be used for a dd around town.
Any suggestions on running a manual tensioner?
Reading info on threads, my main concern is ground clearance(oil pan), any suggestions?
All input is welcome and thanks in advance. Thread has alot of info to read thru.
my setup:
93 civic hatch si
H22a euro r
ITR trans
Exedy stage 1
A Digital Frontier
thinking about buying an h23a blue top and going h2b, any heads up you guys can tell me? itll be going in a EK hatch.
has any one tried fitting itb's in a h2b ef? I really wanna go that route but I need to get some dimensions first.
I don't see a problem doing that on an h2b setup. There's way more clearance back there than straight h. I can change my filter from the top now lol
