**Official H2B Discussion thread **
Old 05-25-2006, 12:28 PM
  #26
xv53's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">it will still work like the rest, plus it will look good with rubber stuck all over the side of it </TD></TR></TABLE>
no rubber on the car for me ...I made some custom wide fenders with a pair that I had lying around don't want to mess up my new paint job
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 &raquo;</TD></TR><TR><TD CLASS="quote">racers from hawaii are already cool </TD></TR></TABLE>
we try to keep it real, among all the ricers we have here...
Old 05-25-2006, 12:46 PM
  #27
skunked's Avatar
Default Re: (xv53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xv53 &raquo;</TD></TR><TR><TD CLASS="quote">
My paint is flawless and his rubber all over it all the time. You can rub vaselene (sp?) on the fenders if you want to keep the rubber from sticking.
Old 05-25-2006, 04:26 PM
  #28
thahuhstunna's Avatar
from everything i've heard on the H2B i can't get it out of my head... search for the tranny currently underway and purchase of kit imminent
Old 05-25-2006, 04:32 PM
  #29
sikciv666's Avatar
Default Re: (thahuhstunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">from everything i've heard on the H2B i can't get it out of my head... search for the tranny currently underway and purchase of kit imminent </TD></TR></TABLE>
do it!
Old 05-27-2006, 07:30 PM
  #30
amy
amy's Avatar
Default Re: (sikciv666)
so...... that alternator... how did you all make it fit? I kept my balance shaft assembly and just removed the belt... I'm shaving down the P/S pulley..
Old 05-27-2006, 09:40 PM
  #31
sikciv666's Avatar
Default Re: (amy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy &raquo;</TD></TR><TR><TD CLASS="quote">so...... that alternator... how did you all make it fit? I kept my balance shaft assembly and just removed the belt... I'm shaving down the P/S pulley.. </TD></TR></TABLE>
explicitspeed.org ....cool *** dude, i bought one for like 75$ shipped..I dont have it yet but when i do ill post some pix..Matt (Skunked) is rockin one
Old 05-27-2006, 09:56 PM
  #32
amy
amy's Avatar
even though i still have the balance shaft assembly?
Old 05-27-2006, 09:58 PM
  #33
sikciv666's Avatar
Default Re: (amy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy &raquo;</TD></TR><TR><TD CLASS="quote">even though i still have the balance shaft assembly? </TD></TR></TABLE>
i think you have to take that out?
Old 05-28-2006, 01:31 AM
  #34
xv53's Avatar
Expltcitspeed sells d series alternator brackets for both applications, with or with out the balance shaft assembly. If you just took out the belt, you would just get the OEM style bracket.
Old 05-28-2006, 12:02 PM
  #35
PhoebeusFenix's Avatar
I need some driving impressions everybody! I have a 93 hatch w/ b16a and a y21 tranny at the moment. I need more power though and am not wanting to boost. I have been researching the h2b for awhile but I dont get the problems with the alternator. I understand the webbing on the back of the block however.
I want some driving impressions. Anybody using this in a dd car? Hows the power? Ive never driven a h22 before, and I think im going to love the torque and power.
Old 05-28-2006, 01:12 PM
  #36
sikciv666's Avatar
Default Re: (PhoebeusFenix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoebeusFenix &raquo;</TD></TR><TR><TD CLASS="quote">I need some driving impressions everybody! I have a 93 hatch w/ b16a and a y21 tranny at the moment. I need more power though and am not wanting to boost. I have been researching the h2b for awhile but I dont get the problems with the alternator. I understand the webbing on the back of the block however.I want some driving impressions. Anybody using this in a dd car? Hows the power? Ive never driven a h22 before, and I think im going to love the torque and power.</TD></TR></TABLE>
The position of the motor with the b series mounts puts the motor so far forward, you need to bring the alt closer to the block..so it'll clear the headlight
Modified by sikciv666 at 10:13 PM 5/29/2006
Old 05-29-2006, 11:12 AM
  #37
hondaZvic's Avatar
Old 05-30-2006, 07:25 AM
  #38
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikciv666 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by sikciv666 at 10:13 PM 5/29/2006</TD></TR></TABLE>
That is NOT the reason. Frame rail to alternator clearance is needed therefore running a SOHC alternator that utilizes a 3 rib belt would give you the needed clearance.
Old 05-30-2006, 07:47 AM
  #39
DC4_MADMAN's Avatar
Couldnt you just run a 3 rib belt on the H alt?
Old 05-30-2006, 07:50 AM
  #40
skunked's Avatar
Default Re: (4door_demon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon &raquo;</TD></TR><TR><TD CLASS="quote">
Couldnt you just run a 3 rib belt on the H alt?</TD></TR></TABLE>
yes, but the prelude still a 5 rib alternator pulley that is too wide. If it's possible to swap a SOHC alt pulley on the H22 alt that should give enough clearance.....
Old 05-30-2006, 08:03 AM
  #41
DC4_MADMAN's Avatar
yes, but the prelude still a 5 rib alternator pulley that is too wide. If it's possible to swap a SOHC alt pulley on the H22 alt that should give enough clearance..... </TD></TR></TABLE>
K, so its not just the belt that needs clearance but the pully as well. Should be easy enough to aquire a SOHC alt.
Old 05-30-2006, 08:08 AM
  #42
skunked's Avatar
yeah, it's the pulley, but the belt is close too. The explicit kit was too easy to buy and install to play with anyhting else IMO.
Old 05-30-2006, 09:46 AM
  #43
amy
amy's Avatar
haha i feel like i've done everything the difficult way
Old 05-30-2006, 10:35 AM
  #44
sikciv666's Avatar
Default Re: (amy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy &raquo;</TD></TR><TR><TD CLASS="quote">haha i feel like i've done everything the difficult way </TD></TR></TABLE>
i mine as well wiped my *** with the directions.
Old 05-30-2006, 10:48 AM
  #45
amy
amy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikciv666 &raquo;</TD></TR><TR><TD CLASS="quote">i mine as well wiped my *** with the directions.</TD></TR></TABLE>
hahahha mr. i'm not gonna shave off the back of my block until the motor is IN the car
Old 05-30-2006, 10:49 AM
  #46
skunked's Avatar
Default Re: (amy)
hahahha mr. i'm not gonna shave off the back of my block until the motor is IN the car</TD></TR></TABLE>
OUCH!!!
Shave it first unless you want to cuss and make your arms sore
Old 05-30-2006, 10:54 AM
  #47
amy
amy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">OUCH!!!
Shave it first unless you want to cuss and make your arms sore </TD></TR></TABLE>
hahah i did mine the right way... Tony wasn't so lucky
I'm so excited, i finished up the wiring last night... All i have left is my suspension and to put the alternator on once i get my relocation kit And then i am DONE!
Old 05-30-2006, 11:14 AM
  #48
skunked's Avatar
Default Re: (amy)
I'm so excited, i finished up the wiring last night... All i have left is my suspension and to put the alternator on once i get my relocation kit And then i am DONE! </TD></TR></TABLE>
nice, put the suspension on and you can get it on the ground
PS-You don't need the alternator for a quick spin around the block open header
Old 05-30-2006, 11:22 AM
  #49
amy
amy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">nice, put the suspension on and you can get it on the ground
PS-You don't need the alternator for a quick spin around the block open header </TD></TR></TABLE>
HAHA that's what iwas planning on
Old 05-30-2006, 11:30 AM
  #50
I guess I did not realize that the alternator is on the front of the h22, interesting. Also, these balancer shafts, are they required to be removed? Or is it optional? Wouldnt this throw off the balance of the engine in general and possibly hurt things?
I am starting to buy things for the swap soon I believe. Is my list correct?
H22A(Can get longblock for $1295 shipped!)
H2B Kit
Aftermarket B series clutch/flywheel/pressure plate
The h2b relocation deal from explicit
What else exaclty? Ive already got my b tranny/axles/ecu. What ecu are you guys running in a eg hatch? Would a p30 work or is a p28 preferred?
Quick Reply: **Official H2B Discussion thread **
