What does EPS mean on your dash? - Honda-Tech
Old 11-16-2005, 06:47 AM   #1
S2GtizNUtz's Avatar
Default What does EPS mean on your dash?
Went back this morning and whack the Map sensor. Reset the ECU. And did the idle reset thing. Where i ran the car at a consistent 3000rpm until the fan came on. Now the EPS comes on in the dash. What does that mean?
S2GtizNUtz is offline   Reply With Quote
Old 11-16-2005, 07:18 AM   #2
Francesco's Avatar
Default Re: What does EPS mean on your dash? (S2GtizNUtz)
Quote:
isn't EPS the electronic steering system? Electronic rack and Pinion Steering?
Francesco is offline   Reply With Quote
Old 11-16-2005, 07:33 AM   #3
jolt-tsp's Avatar
Default Re: What does EPS mean on your dash? (Francesco)
Searched google and found this. It's refering to an NSX but the systems are pretty much the same.
Quote:
Originally Posted by [url
http://www.nsxprime.com/FAQ/Technical/eps.htm[/url]]
If a problem occurs, the control unit turns the system off by actuating a fail-safe relay in the power unit. This eliminates all power assist, causing the system to revert back to manual steering. A dash EPS warning light is also illuminated to alert the driver. To diagnose the problem, a technician jumps the terminals on the service check connector and reads out the trouble codes.
jolt-tsp is offline   Reply With Quote
Old 11-16-2005, 11:30 AM   #4
vortechstook's Avatar
"Electronic Power Steering"
we don't have a hydrolic system like civics/integra's/etc do
vortechstook is offline   Reply With Quote
Old 11-17-2005, 12:51 PM   #5
* B A N N E D *
Did you touch the EPS box at all?
Mr. Projekt is offline   Reply With Quote
Old 11-17-2005, 01:07 PM   #6
WowOzYouRock's Avatar
Default Re: What does EPS mean on your dash? (Slideways2000)
EPS ... Eat , Poo, and Sleep
the light is basically saying, youre a lazy bastard
WowOzYouRock is offline   Reply With Quote
Old 11-17-2005, 01:16 PM   #7
solsurvivor's Avatar
Default Re: What does EPS mean on your dash? (Y2K_S2K)
LOL
solsurvivor is offline   Reply With Quote
Old 11-17-2005, 09:41 PM   #8
SuzukaBlueAP2's Avatar
no no no that's only if you buy an 06 and enjoy the drive-by-wire. that's a lazy bastard.
what's a REALLY lazy bastard, is anyone who buys a new car because it has "rain sensing wipers". Why don't we just make toilets that wipe our asses?
SuzukaBlueAP2 is offline   Reply With Quote
Old 11-18-2005, 01:38 AM   #9
* B A N N E D *
Default Re: What does EPS mean on your dash? (ScreaminTeg)
JDM toilets spray your *** with a stream of water. You're old news man.
Old 11-18-2005, 05:32 AM   #10
jolt-tsp's Avatar
Quote:
Those things are so ridiculous. Takes like 15 minutes to "wipe"! Plus if its laid on thick, I can't imagine the sprayers can get it all. It's like a Jeep that just went mudding going through one of those gas station pressure spray washes.
Old 11-18-2005, 05:55 AM   #11
hypnosisracing's Avatar
Default Re: What does EPS mean on your dash? (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Why don't we just make toilets that wipe our asses?</TD></TR></TABLE>
They do...if you have the money, you can afford to be as lazy as you want.
hypnosisracing is offline   Reply With Quote
Old 11-18-2005, 07:58 AM   #12
Nishant's Avatar
Default Re: What does EPS mean on your dash? (hypnosisracing)
with infinite $, you can do afford anything
Nishant is offline   Reply With Quote
Old 11-18-2005, 10:45 AM   #13
* B A N N E D *
Quote:
I heard the girls enjoy the front sprayers. Damn JDM freaks.
Old 01-17-2006, 11:46 PM   #14
dwolsten's Avatar
Quote:
It's not just laziness. For older people, it's better to use a water sprayer to clean up than toilet paper, because it helps avoid hemorrhoids. I'm not making this up.
dwolsten is offline   Reply With Quote
just need info -light on dash- EPS -whats it mean? WyldRice Acura RSX DC5 & Honda Civic EP3 16 04-18-2007 07:43 PM
What does EP3 mean? NewRacer Acura RSX DC5 & Honda Civic EP3 7 03-14-2004 11:08 PM
what does it mean when your CEL just blinks? DumpedSi Honda Civic / Del Sol (1992 - 2000) 2 08-20-2003 04:40 PM
SRS light stays on.. HELP!! arsenaldragster Honda Civic / Del Sol (1992 - 2000) 7 04-18-2003 04:31 PM
What is the EPS light on the dash? 2camsaam Honda S2000 3 04-16-2003 08:19 PM
Tags
2003, car, civic, dash, ep3, eps, honda, light, mean, means, problem, s2000, stand, warning, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
