lowering S2K problem
hi
i have XYZ Drift spec coilovers .... AP1 S2K ... 235/40 R17
I setup XYZ rear coilovers to max lowering without compression of springs but height is same as with original honda coilovers.
do you have any idea where is problem?
Re: lowering S2K problem
Did you try driving the car for a while? I've had suspension setups stay looking a little high until i've released the e brake after fitting them or until after i've driven a little so the suspension can settle in a bit. Some suspensions don't do it as much but i've seen that as a solution for the strange and unexpected ride height after installing some coilovers or springs and shocks.
PoorBoy_96civic
10
09-26-2010 08:37 AM
