Honda S2000 Honda S2000
Spoon Calipers, wheel fitting guide
Old 12-09-2007, 06:41 AM
  #26
frankdatank's Avatar
do you think spoon calipers will work under my wheels 17x9 +50 17x10 +70?
Old 12-09-2007, 06:55 AM
  #27
LAS2K's Avatar
Default Re: (frankdatank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankdatank &raquo;</TD></TR><TR><TD CLASS="quote">do you think spoon calipers will work under my wheels 17x9 +50 17x10 +70?</TD></TR></TABLE>
i doubt it.
Old 12-09-2007, 08:04 AM
  #28
papa5murf's Avatar
It's not just a matter of width and offsets. When it comes to clearing BBK's, there's also the issue of spoke design.
Old 12-10-2007, 06:43 AM
  #29
papa5murf's Avatar
Default Re: Spoon Calipers, wheel fitting guide (silentdancer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdancer &raquo;</TD></TR><TR><TD CLASS="quote">17inch work meister 2pc
17x8+30
ill get a pic soon.</TD></TR></TABLE>
Still waiting on pics.
On another note, added a few more wheels to the list.
Old 12-10-2007, 02:12 PM
  #30
Default Re: (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">
It's not just a matter of width and offsets. When it comes to clearing BBK's, there's also the issue of spoke design. </TD></TR></TABLE>
i posted the widths and offets. the wheels are ccw classics, so it is a mesh design.
Old 12-10-2007, 02:19 PM
  #31
papa5murf's Avatar
i posted the widths and offets. the wheels are ccw classics, so it is a mesh design.</TD></TR></TABLE>
Old 12-10-2007, 03:19 PM
  #32
similar, no deep dish though.
Old 12-10-2007, 03:25 PM
  #33
papa5murf's Avatar
^ I'll do some research, hopefully I can get you an answer.
Old 12-10-2007, 03:43 PM
  #34
thanks.
Old 12-10-2007, 05:01 PM
  #35
Munkyw3rkz.webs.com
S@nt0s's Avatar
ccw's are SICK AS FUUCK!
Old 12-10-2007, 06:18 PM
  #36
Luder94's Avatar
Default Re: (S@nt0s)
Mugen MF10, S2000 fitment - 15mm spacer
Volk TE37, 18X7.5, +48mm - 15mm spacer
I'm not looking for a pic to post....just trust me.
Old 12-10-2007, 06:22 PM
  #37
papa5murf's Avatar
Default Re: (Luder94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luder94 &raquo;</TD></TR><TR><TD CLASS="quote">Mugen MF10, S2000 fitment - 15mm spacer
What the actual size for the so called "s2000 fitment". I've seen a few different sizes being run.
Old 12-10-2007, 06:26 PM
  #38
papa5murf's Avatar
Just hypothetical, would this also mean the 17x7.5 +48 will fit with the 15mm spacer? Or are 17's too small?
Old 12-10-2007, 08:19 PM
  #39
Luder94's Avatar
MF10's are 7.5" wide with 52mm offsets.
TE37's in 17" with 48mm to 52mm offset will work with 15mm spacers.
...forgot to mention, trying to go 'dumped' with this setup on Spoon calipers is hazardous to your fender's health.
Old 12-10-2007, 08:26 PM
  #40
CWESTINAP1's Avatar
'Volk CE28N 17x9 +54 offset w/ +3mm spacer'
i have these wheels w/ spoon calipers. a 3mm spacer will clear, but only by about 1mm.
i switched to a 5mm hubcentric spacer because the spoon calipers may expand under extreme heat, and they could possibly make contact with the front wheels.
so if u have room, i would recommend a 5mm spacer.
Old 12-12-2007, 08:33 PM
  #41
IIGQ4U's Avatar
Default Re: Spoon Calipers, wheel fitting guide (ricepicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">Enkei RPF1 17X8 +45 offset will clear Spoon Calipers</TD></TR></TABLE>
17x8+45 RPF1s will not clear Spoon calipers without a spacer. You need a minimum 3mm spacer to clear with that wheel size and offset.
17x8+45 BBS LMs will fit with a 5mm spacer
17x8+35 Work VS-XX will fit with a 10mm spacer (Yes, that's right!)
Old 12-12-2007, 08:34 PM
  #42
IIGQ4U's Avatar
If you have the wheels on your car, simply measure the distance from the rotor to the rear of the spokes. You will need approximately 2.25" from the rotor to the spokes to clear safely.
Old 12-20-2007, 06:21 AM
  #43
papa5murf's Avatar
Default Re:
Updated!
Old 01-13-2008, 05:01 PM
  #44
wu`
wu`'s Avatar
Um would TE37s 16*7 +42 clear spoon calipers without spacers?
Old 02-22-2008, 04:50 AM
  #45
papa5murf's Avatar
Default Re:
Updated, added two wheels to the list.
Old 02-22-2008, 06:01 AM
  #46
Luder94's Avatar
Default Re: Re: (papa5murf)
I'll be checking fitment with some 18" BBS LMs this weekend. Don't know the offset, hopefully it's stamped on the wheels.
I'll report back sometime this weekend.
Old 02-22-2008, 06:07 AM
  #47
papa5murf's Avatar
Default Re: Re: (Luder94)
LM's. &lt;3
Old 02-22-2008, 10:59 AM
  #48
ricepicker's Avatar
Default Re: Spoon Calipers, wheel fitting guide (IIGQ4U)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IIGQ4U &raquo;</TD></TR><TR><TD CLASS="quote">
17x8+45 RPF1s will not clear Spoon calipers without a spacer. You need a minimum 3mm spacer to clear with that wheel size and offset.</TD></TR></TABLE>
Thanks for the clarification, there was no mention that spacers were used. So I'm sorry papa, for the misinformation
Old 02-22-2008, 07:49 PM
  #49
IIGQ4U's Avatar
LMs will clear with about a 40 offset. I have LMs now and about a finger gap between my spokes and the caliper.
Old 02-23-2008, 10:35 AM
  #50
papa5murf's Avatar
Default Re: Re: (IIGQ4U)
^ Wheel size?
Quick Reply: Spoon Calipers, wheel fitting guide
