S2000 EPS light on/won't go pass 5k rpm/limp mode??
My s2k EPS light is on and I tried checking the code but can't seem how to read the code... My abs light blinks when I'm checking my code same as my EPS light too.. From what I'm reading how my eps light is blinking is 1st (pause light, pause light, blink, blink) 2nd (pause light,pause light, blink, blink,blink) with that I think that's code p0022&p0023?? Correct me if I'm worng!! And with that my eps light is on my Trans on 2nd gear is out where I think that's why my eps light is on n won't let me go pass 5k rpm and where I'm reading my code that it's giving me a different code beside like my speed sensor on my Trans!! Plus btw I'm running a aem ems ecu on the car!!
Lmk if u guys can help me out on my problem:
From what I no is on other car like B series if one of ur gear is out u can still rev it pass rpm n no code will pop up but with my s2k now it pop up after my 2nd gear with out? N my speedometer stop working too??
1 Post
Re: S2000 EPS light on/won't go pass 5k rpm/limp mode??
Idk how you are reading codes without an actual device, but I'd suggest finding out those CEL codes first. If the eps is on you should experience difficulty turning the wheel. EPS=electronic power steering, What year is your s2000? Stop guessing those codes and have them read!
P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 "B" Camshaft Position - Actuator Circuit (Bank 2)
It's a 2000.. And my power steering is fine.. I tried using the scanner to check the code and it won't chatch it.. Cuz I'm running on the aem ems on the car!!
Aem v1 n I couldn't dialog it cuz I haven't upload the software!! Could I fine what wrong if I have it up load on the software??
