S2000 clutch acting funny - Honda-Tech
Old 01-27-2017, 07:59 PM   #1
Icon5 S2000 clutch acting funny
Okay so a few days ago I was out driving my 2001 s2000, which I just replaced the engine with a 03 f20c with fewer miles. Put a brand new oem clutch in as well. But as I was driving the clutch pedal got stiffer and started to kind of stick down. It always comes back up, but it hesitates a little. I figured it would be the master or slave cylinder so I replaced both. But of course it's till doing it. I went out driving tonight and decided to do a hole shot. As soon as I did the clutch started working fine for about 2 minutes then went back to being hard and hesitating. Doesn't slip and shifts easily as well. (Yes I bled the clutch extremely well) Thoughts?
kfoster1234 is offline   Reply With Quote
Old 01-28-2017, 06:46 PM   #2
Arsenal's Avatar
Default Re: S2000 clutch acting funny
s2ki.com or google. Very little traffic here
Arsenal is offline   Reply With Quote
Old 02-15-2017, 06:01 PM   #3
JDMH22HATCH's Avatar
Try putting Urea grease on the contact points of the clutch fork and bearing. Also where the fork pivots. I believe there is an old bulletin for this problem. Had the same problem with an 01 a while back and it fixed the problem.
JDMH22HATCH is offline   Reply With Quote
HELP!! 2000 Accord hesitation and stumbling finally leads to no start DaveMcG6thGen Honda Accord (1990 - 2002) 9 12-21-2015 05:00 AM
Possible ignition problem, or slipping (new) clutch iplayloudly Tech / Misc 3 12-01-2014 02:08 PM
92' Civic DX Stalling, Hesitating, and Brake lights stuck on mrbarwrobert Honda Civic / Del Sol (1992 - 2000) 2 06-17-2014 12:29 PM
Lightweight Flywheel and a smell? 00CivicGirl Acura Integra 6 08-10-2008 04:08 PM
Ignitor/Coil Problem.. KyleVA Honda Civic / Del Sol (1992 - 2000) 2 11-12-2006 06:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
