Honda S2000 Honda S2000
Quick Comp test [disable injectors]
Old 01-30-2009, 06:11 AM
ExVtec's Avatar
Default Quick Comp test [disable injectors]
On my Si, I could easily pull a fuse and disable the injectors from pulsing while I checked comp. Is there an easy way on this car to do the same w/o unplugging each injector?
Thanks.
Old 01-30-2009, 06:15 AM
joey1320's Avatar
Default Re: Quick Comp test [disable injectors]
you can pull off the fuel pump fuse and run the car until it dies or just pull the connectors, it will only take 1 minute.
Old 01-30-2009, 09:07 AM
h_s
h_s's Avatar
yank off the main relay - it will disable fuel and spark
Old 01-31-2009, 05:02 PM
ExVtec's Avatar
Where, the underhood fuse box?
Old 01-31-2009, 05:43 PM
HondaKyle's Avatar
i didnt have to let it run...
sgull
01-30-2013 08:21 PM
BB6-213
12-11-2010 09:33 AM
jay-tec
12
12-06-2004 06:28 PM
JDM_ITR
07-06-2003 09:53 AM
hmonglonertim
05-03-2002 12:29 PM
Quick Reply: Quick Comp test [disable injectors]
