Honda S2000 Honda S2000
Quarts of oil
Old 03-25-2007, 09:49 AM
cheese steak Nazi's Avatar
Default Quarts of oil
stupid question , but when i bought my car used they guy didnt have the owners manual... when i change the oil id like it to be manual specs ..so i just want to know exactly how many quarts of oil the S takes, so i know how many quarts to buy. dont wanna run short halfway through the change
Old 03-25-2007, 09:51 AM
LAS2K's Avatar
Default Re: Quarts of oil (Cheese Steak ****)
Old 03-25-2007, 09:54 AM
* B A N N E D *
Mr. Projekt's Avatar
Buy 6, put in 5.3 if it's an AP1, and 5.1 if it's and AP2.
Old 03-25-2007, 11:11 AM
Default Re: Quarts of oil (Mr. Projekt)
Old 03-25-2007, 11:35 AM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Buy 6, put in 5.3 if it's an AP1, and 5.1 if it's and AP2. </TD></TR></TABLE>
i think you may have that reversed, or maybe some other reason for the 5.3 for ap1.....
my owners manual says 5.1 for my 02' ap1
not that .2 is that big of a difference
Old 03-25-2007, 01:10 PM
S2SLOW's Avatar
Correct...
Old 03-25-2007, 03:27 PM
cmdr430's Avatar
Default Re: Quarts of oil (S2SLOW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW &raquo;</TD></TR><TR><TD CLASS="quote">
Correct... </TD></TR></TABLE>
looks like there are some discrepencies in all of our answers.....
mr projekt says 5.3 for ap1 and 5.1 for ap2
i said my owners manual shows 5.1 for ap1
these pages show 5.6 for 02 ap1 04 ap2 and 06 ap2
http://www.hondanews.com/categ...=2002
http://www.hondanews.com/categ...=2004
http://www.hondanews.com/categ.../2948
Old 03-25-2007, 03:36 PM
m R g S r's Avatar
just make sure the car is on level ground (gas station platforms are almost always level....
and check the oil there, make sure it's up to the full mark...or close to it...
Old 03-25-2007, 04:27 PM
S2SLOW's Avatar
Default Re: Quarts of oil (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
The manual is wrong, just look at the dipstick...Mine on 5 quarts is in the middle of the 2 marks for low and high...
Old 03-25-2007, 04:55 PM
cmdr430's Avatar
The manual is wrong, just look at the dipstick...Mine on 5 quarts is in the middle of the 2 marks for low and high... </TD></TR></TABLE>
damn.....i cant believe f'd up like that.....
hondas are going down the sh_tter.....
Old 03-25-2007, 10:33 PM
* B A N N E D *
5 full quarts bring me to about 1 hash mark off the top, consistently.
Old 03-26-2007, 05:09 PM
iam7head's Avatar
just go according to the dipstick, how hard is that?
clean, check, clean, check
Old 03-26-2007, 06:04 PM
DavidR's Avatar
According to the service manual for 07:
And my care, cause its awsome
Old 03-26-2007, 10:16 PM
JAR AP1's Avatar
I usually run 6 quarts. I have noticed that my car likes the added oil (y)
But when all else fails go by the dipstick.
Old 03-26-2007, 10:18 PM
* B A N N E D *
Default Re: (JAR AP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JAR AP1 &raquo;</TD></TR><TR><TD CLASS="quote">I usually run 6 quarts. I have noticed that my car likes the added oil (y)
But when all else fails go by the dipstick.</TD></TR></TABLE>
Horrible advice. Too much oil = more windage losses. No wonder your damn name rings a bell.
Old 03-27-2007, 03:53 PM
JAR AP1's Avatar
Default Re: (Mr. Projekt)
quote from max rev
"Highly recommended for track S2000s. I typically overfill my car with about 6 quarts of synthetic oil."
http://www.maxrev.net/index.ph...c.htm
Old 03-27-2007, 04:03 PM
* B A N N E D *
"Highly recommended" was referring to the baffled oil pan genius.
Old 03-27-2007, 09:28 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JAR AP1 &raquo;</TD></TR><TR><TD CLASS="quote">quote from max rev
http://www.maxrev.net/index.ph...c.htm</TD></TR></TABLE>
too much oil=turn into foam and foam have no protection again wear,tear, cooling, cushioning property of oil
Old 03-28-2007, 07:41 AM
hayabusa160's Avatar
Default Re: (iam7head)
i usually add around 5.5 quarts at work when i service a s2k but so far i only serviced ap2s
i never had an ap1 come in yet. when it gets warmer they all will be coming out.
Old 03-28-2007, 08:14 PM
JAR AP1's Avatar
I do have a baffled oil pan and i have been running 6 quarts for a while now. I understand about what overfilling can cause, but the car seems to like that added oil.
Old 04-01-2007, 07:41 AM
VTECorona's Avatar
According to Helms for MY00-03:
4.8 quarts - oil change
5.1 quarts - oil change w\ filter
5.9 quarts - engine overhaul
I usually just buy the 5 quart jug for my oil changes. After about 2000 miles, my engine "makes room" for another quart and I add it. As long as you are between the lines on your dip stick then you are ok.
Old 04-01-2007, 08:29 AM
Nishant's Avatar
Default Re: (VTECorona)
Simple answer... put in 5 quarts, check the dipstick. Pour in whatever is necessary!
chiquito
Honda Civic (2006 - 2015)
09-24-2007 09:50 AM
quilter@atlanticbb.net
10
07-20-2007 12:06 AM
01-0720
Honda Motorcycles
15
01-19-2005 06:15 AM
shinra
02-19-2004 06:46 AM
hndarcrb18c1
08-16-2003 04:56 PM
Quick Reply: Quarts of oil
