Honda S2000 Honda S2000
S2000 rear wheels...
Old 04-13-2001, 09:27 AM
S13Koop's Avatar
Default S2000 rear wheels...
I might possibly buy a set of S2000 wheels but of course I don't need the rear ones. Would anyone be interested if some became available?
(:Kibro???)
Old 04-13-2001, 06:35 PM
Saga's Avatar
Default Re: S2000 rear wheels... (YellowStreak_R)
so the front wheels will fit a ITR?
Old 04-14-2001, 03:13 PM
S13Koop's Avatar
Default Re: S2000 rear wheels... (Saga)
Yea, only the front fits, just like the NSX wheels, the rears are too wide and will rub.
Old 04-14-2001, 11:41 PM
grippgoat's Avatar
You sure the offset is gonna work? 91-93 NSX front wheels are 15x6.5 +55mm. That seems like it would rub on the ITR. I'm pretty sure that the S2000 wheels are also high offset, since the S2000 suspension is pretty much just a scaled-down version of the NSX.
-Mike
Old 04-16-2001, 08:17 PM
New User
royboy's Avatar
Default Re: S2000 rear wheels... (grippgoat)
yup, ITR wheel dimensions are 15x6.5 & +55mm offset, too.
-Roy
Old 04-16-2001, 09:34 PM
grippgoat's Avatar
Default Re: S2000 rear wheels... (royboy)
No they're not. ITR wheels are 15x6 +42 or +43. They *might* be x6.5, but I'm 99% sure they're only x6. I know know the offset is either +42 or +43, cuz it's 2-3mm less than a GSR, which is +45mm. With a +55mm welcome to Rubsville, population: you.
-Mike
Old 04-17-2001, 10:30 AM
97ITR274's Avatar
Hey YellowStreak_R,
I will let you know as soon as I decide to part with them. hehehehe. They are heavy though.
Check out http://www.s2000online.com on the Group Buy/Sale section. I've seen some peeps that sells theirs for cheap, with tires too!
:Kibro
Old 04-17-2001, 10:33 AM
97ITR274's Avatar
Default Re: S2000 rear wheels... (97ITR274)
The offset of the stock ITR wheel should be found at the back of the side of the rim. Should be embossed in one of the creases of the spoke. If memory serves me right, it's +50mm. Not sure tho. I'm sure YellowStreak can check his.
Later
:Kibro
jvtec95
12-06-2009 03:23 PM
NashDishesDimes
Honda S2000
48
03-06-2009 12:10 PM
ScOeDeLiC
Acura TSX
27
02-22-2009 06:22 PM
ITR77
01-08-2004 09:37 AM
rudeS2k
09-02-2002 02:09 PM
Quick Reply: S2000 rear wheels...
