Honda S2000 Honda S2000
lowering S2K problem
Old 10-12-2016, 11:09 AM
kingart's Avatar
Default lowering S2K problem
hi
i have XYZ Drift spec coilovers .... AP1 S2K ... 235/40 R17
I setup XYZ rear coilovers to max lowering without compression of springs but height is same as with original honda coilovers.
do you have any idea where is problem?
Old 10-19-2016, 09:42 AM
KankakeeLocal's Avatar
Default Re: lowering S2K problem
Did you try driving the car for a while? I've had suspension setups stay looking a little high until i've released the e brake after fitting them or until after i've driven a little so the suspension can settle in a bit. Some suspensions don't do it as much but i've seen that as a solution for the strange and unexpected ride height after installing some coilovers or springs and shocks.
Old 10-20-2016, 01:55 AM
kingart's Avatar
i drive with these coilovers very long
have S2k height at suspension geometry settings?
m.glisson003
Suspension & Brakes
08-06-2011 01:49 PM
PoorBoy_96civic
10
09-26-2010 08:37 AM
civic01coupe
Honda Civic (2001 - 2005)
03-07-2008 02:34 PM
xlusiveracer
06-27-2005 10:09 AM
alfaaay
05-23-2005 01:51 PM
Quick Reply: lowering S2K problem
